Turbo corvair 914, Do two wrongs make a right |
garrettlee2 |
Oct 18 2020, 05:12 PM
Member Group: Members Posts: 158 Joined: 8-September 12 From: riverside ca Member No.: 14,901 Region Association: None |
https://losangeles.craigslist.org/sfv/cto/d...7215968205.html they say you can’t turbo a 914 and corvair are bad
gandalf_025 |
Oct 18 2020, 08:48 PM
Senior Member Group: Members Posts: 1,453 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
Also looks to have 4 carb, Corvair 140 hp heads. You can see 1
of the carb mounts blocked by a solid plate. 140 hp heads had larger valves so I don't think Corvair turbo sodium exhaust valves fit..?? They made adapters for 1 3\4" SU carbs and Weber 45 DCOE carbs. Both were supposed to be an improvement over the factory Carter. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:05 AM |
