Fan belt access on a /6 once car is installed |
Tdskip |
Oct 22 2020, 09:56 AM
If I need to adjust (or even replace) a fan belt on the 3.2L is in the car is there enough access to do that if the firewall sound deadening has been removed?
Fiddly at best would be my guess... Thanks! |
Superhawk996 |
Oct 22 2020, 10:24 AM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
If I need to adjust (or even replace) a fan belt on the 3.2L is in the car is there enough access to do that if the firewall sound deadening has been removed? Fiddly at best would be my guess... Thanks! 1st rule of mid engine cars applies -- Drop the engine. (IMG:style_emoticons/default/biggrin.gif) Mark Henry and others have created access panels for easy access. For me that isn't an option. I just cant bring myself to cut a hole like that though I'm sure it works for fan access and alternator replacment. Early on in my teener ownership I just learned to drop the engine. I will grant that dropping a six is not as simple as dropping the type 4. However, I still see it as the price of entry to the mid-engine cars. Pantera might the the only mid engine car that I can think of that looks remotely serviceable. Had a work acquaintenace that owned a Ferrari 308. Same schtick. All sorts of creative ways to try to service stuff with engine in but he concedes that it was usually quicker to just drop the engine. |
Mark Henry |
Oct 22 2020, 11:24 AM
If I need to adjust (or even replace) a fan belt on the 3.2L is in the car is there enough access to do that if the firewall sound deadening has been removed? Fiddly at best would be my guess... Thanks! 1st rule of mid engine cars applies -- Drop the engine. (IMG:style_emoticons/default/biggrin.gif) Mark Henry and others have created access panels for easy access. For me that isn't an option. I just cant bring myself to cut a hole like that though I'm sure it works for fan access and alternator replacment. (IMG:style_emoticons/default/biggrin.gif) This makes my life so much easier. https://www.youtube.com/watch?v=/4CaU9UQmFfk?t=58 |
Steve |
Oct 22 2020, 05:20 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
If I need to adjust (or even replace) a fan belt on the 3.2L is in the car is there enough access to do that if the firewall sound deadening has been removed? Fiddly at best would be my guess... Thanks! 1st rule of mid engine cars applies -- Drop the engine. (IMG:style_emoticons/default/biggrin.gif) Mark Henry and others have created access panels for easy access. For me that isn't an option. I just cant bring myself to cut a hole like that though I'm sure it works for fan access and alternator replacment. (IMG:style_emoticons/default/biggrin.gif) This makes my life so much easier. https://www.youtube.com/watch?v=/4CaU9UQmFfk?t=58 I will be cutting a hole when my alternator dies, but not before. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:27 AM |
