Fan belt access on a /6 once car is installed |
Tdskip |
Oct 22 2020, 09:56 AM
If I need to adjust (or even replace) a fan belt on the 3.2L is in the car is there enough access to do that if the firewall sound deadening has been removed?
Fiddly at best would be my guess... Thanks! |
ClayPerrine |
Oct 22 2020, 04:23 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I will NOT cut a hole in something called a "FIREWALL"
That being said, Clewett engineering makes a serpentine belt kit for the 911 engines. It is a bolt on, and all you need to replace a belt is a 3/8 inch breaker bar. Just pull back the tensioner, and install the belt. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.clewett.com-1143-1603405557.1.JPG) On the factory six, I have the special wrench it takes to replace the belt. It can be done in the car, but it takes patience. I change the belt every time I pull the engine, no exceptions. And I do that to adjust the valves. Honestly, if I have to put a belt on in the field, I will just roll it on over the pulley. It will work until I can get the car home. |
Superhawk996 |
Oct 23 2020, 03:58 PM
914 Guru Group: Members Posts: 5,830 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I will NOT cut a hole in something called a "FIREWALL" That being said, Clewett engineering makes a serpentine belt kit for the 911 engines. It is a bolt on, and all you need to replace a belt is a 3/8 inch breaker bar. Just pull back the tensioner, and install the belt. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.clewett.com-1143-1603405557.1.JPG) I really find this appealing but didn't someone just run into a clearance issue between serpentine belt pulley and the crank fire ignition tone wheel from Clewitt? @nditiz1 ? |
Lo-Fi Version | Time is now: 19th May 2024 - 12:15 PM |
