Fan belt access on a /6 once car is installed |
Tdskip |
Oct 22 2020, 09:56 AM
If I need to adjust (or even replace) a fan belt on the 3.2L is in the car is there enough access to do that if the firewall sound deadening has been removed?
Fiddly at best would be my guess... Thanks! |
nditiz1 |
Oct 23 2020, 04:30 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I did run into issues with the OEM style mount and that Clewett kit. Somebody could make it work.
I too am NOT going to be cutting a hole. If it needs adjusting or replacing, I will just drop the engine. |
Superhawk996 |
Oct 23 2020, 04:44 PM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I did run into issues with the OEM style mount and that Clewett kit. Somebody could make it work. I too am NOT going to be cutting a hole. If it needs adjusting or replacing, I will just drop the engine. @nditiz1 Thanks! I thought there was something about it. I definately plan to use the OEM style mount for NVH reasons. Hmm. (IMG:style_emoticons/default/idea.gif) Did you happen to grab a picture of how bad the interference was? I wonder If I could modify a MadDog mount to make it work? |
Lo-Fi Version | Time is now: 17th May 2024 - 01:57 AM |
