Another Master Cylinder Reservoir headache thread, Hose fittings would have been nice, porsche |
betz |
Oct 22 2020, 10:14 AM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
I did a lot of searching but none really have quite the same issue I'm having.
So I installed a new master cylinder a while back, wrestled around with the reservoir flared fittings into the grommets, etc etc, finally got it in somehow. FYI- this is a URO parts master cylinder. I am wary of URO parts not always being the best quality but the @UROpartsman seems to stand behind their products and makes revisions based on feedback so I trust it well enough. So anyways, got it installed, but it was leaking just small little drops from the reservoir fitting towards the front of the car. Enough to drain the reservoir overnight. Did some searching and saw that many people forget the washers. But also see the Uro master cylinder has them pre-installed as of a recent revision. I take the safe road and buy a couple of washers, right part number genuine porsche. Pull out my master cyl again, pull out the grommets, of course it already had washers in there. Since I got this far I replaced the washers anyways, and reinstall everything. NOW, it doesn't drip drop. It's a constant stream, leaking like a sieve. Front fitting again, the back one if it leaks, doesn't leak nearly as much. I wrestle with the fittings even more and may have gotten it down to a profuse drop. But the fittings were pushed all the way into the cylinder as far as I could tell! No amount of wrestling got them any further. And I was pushing into it pretty hard. Seems like maybe the angle had an effect on how much it was leaking. But is it really to the point that you need to just get them in just perfect or else it will leak? Seems like normal driving could move it around. I would think it's just, if it's in it's in. My solution for now is I guess I'll buy new grommets? I'm just wondering if there's any case that that the flare fitting is only partially seated, or did I just wrestle with it too much and somehow damage the grommets? How can I tell it's seated? Anyways I got some Ate brand grommets on the way since that's the only thing I could think of causing the leak. Would appreciate any insight, thanks. |
UROpartsman |
Oct 22 2020, 11:04 AM
Member Group: Members Posts: 291 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
But is it really to the point that you need to just get them in just perfect or else it will leak? Hi Betz, unfortunately that's the case; for a good seal against the neck of the flare and around the tubing, the line must be completely seated with the flare between the stand-off washer and the bottom of the grommet. It is very difficult to do given the tight quarters. If the flare isn't pushed all the way through the grommet, the flare will spread the ID of the grommet and create a leak path. Hopefully starting fresh with new grommets and a bit of practice under your belt will mean success on your next attempt. Please PM us if you have any questions. |
betz |
Oct 22 2020, 11:54 AM
Hi Betz, unfortunately that's the case; for a good seal against the neck of the flare and around the tubing, the line must be completely seated with the flare between the stand-off washer and the bottom of the grommet. It is very difficult to do given the tight quarters. If the flare isn't pushed all the way through the grommet, the flare will spread the ID of the grommet and create a leak path. So basically, the flare needs to be right up against the washer, with the rubber right above / around it? Should I try working the grommet around the flare to help it seat? So, normally when this is installed. Is the hard part getting the flare into the grommet, or getting the flare all the way into the grommet? |
Lo-Fi Version | Time is now: 18th May 2024 - 10:51 AM |
