WTB 2056 kit or complete engine |
william1764 |
Oct 22 2020, 02:38 PM
Member Group: Members Posts: 252 Joined: 11-May 10 From: maryland Member No.: 11,717 Region Association: MidAtlantic Region |
Considering rebuilding my 2.0 to a 2056 or replacing engine with quality 2056 build already completed. Where can I find list of parts/work involved in a 2056 build? Thanks in advance!
Al Meredith |
Oct 23 2020, 03:16 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I'm just about to start building a 2056. I have everything needed but the pistons. I have a brand new in the box set of AMC European heads done by Len Hoffman . They have 2.0L valves (42X36) SS valves , HD springs, Chrome molly retainers . The difference with these heads is that were made from 1.8 castings and have a 1.8L sparkplug location. They would take 1.7/1.8 Tin. I have a polished STD /STD crank and rebushed rods that are matched weight. I have 4 German barrels bored to 96 MM . I have a cam stamped "weber 76" We degreed it to be 233 deg at .50 with a lift or .400 ,lobe CL at 106.5. This is the same as a Webcam #86. Needles to mention I have cases , coolers , oil pumps , nuts /bolts . everything you need to build from scratch . Here is another Idea, I have a rebuilt 1.7 on my engine run up stand now. I'll sell it for $1000 as a short block and you could install it in your car while you rebuild the original . It's OK to call me if you want to discuss . AL Meredith 770-616-3767
Lo-Fi Version | Time is now: 21st May 2024 - 12:11 PM |
