b and c fire extinguisher, on sale |
brcacti |
Oct 22 2020, 04:50 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
saw some b and c extinguishers at home depot on sale would that work for the 914s?
bkrantz |
Oct 22 2020, 05:42 PM
914 Guru Group: Members Posts: 7,666 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
brcacti |
Oct 22 2020, 05:54 PM
saw some b and c extinguishers at home depot on sale would that work for the 914s? Can you provide a link? I recently bought Purple K extinguishers for all my cars. https://www.homedepot.com/p/Kidde-Code-One-...28347/312602847 for about $10. disposable |
second wind |
Oct 22 2020, 06:23 PM
Senior Member Group: Members Posts: 847 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Aren't these the type that destroy your engine metal? Where can you get a superior type for a good price? Appreciate your post though and correct me if I am wrong. Thank you very much.
gg |
Coondog |
Oct 22 2020, 07:33 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Aren't these the type that destroy your engine metal? Where can you get a superior type for a good price? Appreciate your post though and correct me if I am wrong. Thank you very much. gg While I only use purple K fire extinguishers, the dry powder ABC extinguishers get a bum wrap about the damage they do. All powder extinguishers make a mess but if you wash it off they wont do any more or less harm then a fire would do. Wash it off and your good, of course the fire department will do that for you. Buy a Purple K and let someone else go to Home Depot. |
second wind |
Oct 22 2020, 08:17 PM
gg |
Coondog |
Oct 22 2020, 09:23 PM
Aren't these the type that destroy your engine metal? Where can you get a superior type for a good price? Appreciate your post though and correct me if I am wrong. Thank you very much. gg Wash it off and the problem goes away. To answer your question correctly if you leave in on your engine for a long period of time, then yes. But who does that ?? Purple K extinguishers put out fuel fires far better then other dry power extinguishers. Again wash of the residue. Purple-K, also known as PKP, is a dry-chemical fire suppression agent used in some dry chemical fire extinguishers.[1] It is the second most effective dry chemical in fighting class B (flammable liquid) fires after Monnex (potassium allophanate), and can be used against some energized electrical equipment fires (USA class C fires). It has about 4–5 times more effectiveness against class B fires than carbon dioxide, and more than twice that of sodium bicarbonate. Some fire extinguishers are capable of operation in temperatures down to −54 °C or up to +49 °C. Dry chemical works by directly inhibiting the chemical chain reaction which forms one of the four sides of the fire tetrahedron (heat + oxygen + fuel + chemical chain reaction = fire). To a much smaller degree it also has a smothering effect by excluding oxygen from the fire. "Dry chemical" extinguishers, such as Purple-K, are different from "dry powder" extinguishers that are used to fight Class D flammable metal fires. PURPLE K extinguishers contain specially fluidized and siliconized potassium bicarbonate dry chemical which is particularly effective on Class B flammable liquids and pressurized gases. ... ABE dry chemical (ammonium phosphate) fire extinguishing agent is known to cause corrosion to aluminum aircraft components. Buy them from Amazon. Pretty cheap insurance. |
Coondog |
Oct 22 2020, 09:26 PM
saw some b and c extinguishers at home depot on sale would that work for the 914s? Can you provide a link? I recently bought Purple K extinguishers for all my cars. https://www.homedepot.com/p/Kidde-Code-One-...28347/312602847 for about $10. disposable 5 BC fire extinguisher is only rated to put out 5 square feet of a fuel fire. Great ext for the kitchen or inside your motorhome but other then that not much fire power, excuse the pun...... |
Lo-Fi Version | Time is now: 28th March 2024 - 11:49 AM |
