Road Test, Slow acceleration and valve chatter |
VA_914 |
Oct 25 2020, 01:12 PM
Newbie Group: Members Posts: 4 Joined: 31-March 08 From: Hampton, VA Member No.: 8,873 Region Association: MidAtlantic Region |
I am finally road testing my 2.0 restoration and haven't quite got it right yet. It starts fine, runs smooth idling or revved up in the driveway but on the road test it accelerated slow, with what sounds like valve chatter when I give more gas to accelerate. It wouldn't go over 3000 rpm in 1st, 2nd or third. I tweaked the timing a bit and it seemed to get better, less chatter and almost up to 4000 rpm. Suggestions, comments; am I on the right track?
VA_914 |
Oct 29 2020, 10:24 AM
John came over yesterday and after pushing the car back and forth in 4th gear for an hour looking for timing marks, we finally decided to start it. He immediately said it wasn’t firing on all cyclinders and after a little checking it seemed both 3&4 were’t firing with loose wires/connectors being the likely suspect. Thanks for the help John and hopefully I can get it resolved in the next day or two.
BeatNavy |
Oct 29 2020, 10:36 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
John came over yesterday and after pushing the car back and forth in 4th gear for an hour looking for timing marks, we finally decided to start it. He immediately said it wasn’t firing on all cyclinders and after a little checking it seemed both 3&4 were’t firing with loose wires/connectors being the likely suspect. Thanks for the help John and hopefully I can get it resolved in the next day or two. (IMG:style_emoticons/default/smilie_pokal.gif) @wndsrfr Loose injector connectors? I had a really annoying minor issue where my #3 injector wire would pop out at random times. Usually happened when I was really enjoying a great ride with little traffic marveling how well the engine was running and sounding. I knew immediately when it happened, and because it was #3 the CHT gauge would show rapidly dropping head temps and the AFR gauge would go really lean. Then I'd have to find a safe place to pull over, pop the engine lid, etc. It wasn't a big deal but it was a buzz kill for my teener cruising bliss at the moment. |
Lo-Fi Version | Time is now: 13th May 2024 - 01:10 AM |
