Road Test, Slow acceleration and valve chatter |
VA_914 |
Oct 25 2020, 01:12 PM
Newbie Group: Members Posts: 4 Joined: 31-March 08 From: Hampton, VA Member No.: 8,873 Region Association: MidAtlantic Region |
I am finally road testing my 2.0 restoration and haven't quite got it right yet. It starts fine, runs smooth idling or revved up in the driveway but on the road test it accelerated slow, with what sounds like valve chatter when I give more gas to accelerate. It wouldn't go over 3000 rpm in 1st, 2nd or third. I tweaked the timing a bit and it seemed to get better, less chatter and almost up to 4000 rpm. Suggestions, comments; am I on the right track?
BeatNavy |
Oct 29 2020, 01:23 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
If it's both #3 and #4 not firing then it is more likely to be grounds, as Phil suggests, and not trigger points. Injectors 3 and 4 share a common ground. Trigger point pairs are 1/3 and 2/4.
Yes, remove air cleaner, look for the three prong ground at the rear of the case. Clean, tighten, etc. etc. |
Lo-Fi Version | Time is now: 13th May 2024 - 07:34 AM |
