Sold - Restored Rear Sway Bar - $350, Price dropped from $400 to $350 |
bdstone914 |
Oct 28 2020, 07:09 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
This is an original rear sway bar with all parts needed for installation.
The drop links and bar are powder coated. New bushing for drop links are installed. One bushing is on order. Pictured are used rubber bushing but new ones are on order and will be included. Sway bar bushing brackets are zinc plated. The shock bolts are cleaned and polished and soaked in hot oil to retard rust. Replated shock bolt nuts are included with new lock washers ( not pictured). If your car was not originally equipped with a rear sway bar you will need the weld in brackets that mount to the bottom of the trunk floor or drill holes and use support plates in the trunk. $350 plus shipping from Riverside CA 92505 or local pickup. Attached thumbnail(s) |
SO.O.C914er |
Oct 28 2020, 07:21 PM
Senior Member Group: Members Posts: 1,249 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
Bruce if you put together a front one I’m good for that.....thanks Paul (IMG:style_emoticons/default/driving.gif)
bdstone914 |
Oct 28 2020, 07:30 PM
Bruce if you put together a front one I’m good for that.....thanks Paul (IMG:style_emoticons/default/driving.gif) I had one and it sold before I got it listed. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:48 AM |
