Malibu Run:, Thanksgiving Weekend Saturday 11/28 |
914_7T3 |
Nov 1 2020, 03:57 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Looking to head out with a group of SoCal teeners in the Canyons of Malibu on Saturday 11/28.
We can meetup for coffee, take a few hours for a drive and plan a stop for lunch. Just chime in if you are interested and I'll plan a teener appropriate route. It would be great if we could get the OC & San Diego guys up to enjoy the roads out this way. (IMG:style_emoticons/default/driving.gif) Route Information can be found in post #19 Confirmed @914_7T3 @jim_hoyland @MM1 @second_wind @Tonyooc @campbellcj @Robarabian @ValcoOscar @914Toy @Drem914 @Steve @Coondog @mxkinn01 @Mike D. @ 914 RZ-1 Maybe @DANNYMAC --- WARNING: Too many @ tags! --- |
mxkinn01 |
Nov 29 2020, 06:54 PM
Member Group: Members Posts: 224 Joined: 18-June 17 From: Las Vegas, NV Member No.: 21,195 Region Association: Southwest Region |
So I get back to Vegas and unload the car and of course it runs great. No lean mis, no high idle (around 1800 - 2200 is where it was in Malibu), no coughing or sputtering or loss of power. Checked all the vacuum lines and they looked good. Auxiliary air regulator seems to be functioning (although its always hunted when cold). For good measures I'll be replacing all the vacuum lines. Might be time to fix or replace the MPS.
Anyways, it was great meeting all of you. Cant wait until next time. Thanks Mike |
914_teener |
Nov 29 2020, 07:25 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
So I get back to Vegas and unload the car and of course it runs great. No lean mis, no high idle (around 1800 - 2200 is where it was in Malibu), no coughing or sputtering or loss of power. Checked all the vacuum lines and they looked good. Auxiliary air regulator seems to be functioning (although its always hunted when cold). For good measures I'll be replacing all the vacuum lines. Might be time to fix or replace the MPS. Anyways, it was great meeting all of you. Cant wait until next time. Thanks Mike Might want to check for a leaky decel valve if you have one or the adjustment. If it is cracked or leaky it will do this. Assuming you are running D-jet. |
mxkinn01 |
Nov 29 2020, 08:08 PM
So I get back to Vegas and unload the car and of course it runs great. No lean mis, no high idle (around 1800 - 2200 is where it was in Malibu), no coughing or sputtering or loss of power. Checked all the vacuum lines and they looked good. Auxiliary air regulator seems to be functioning (although its always hunted when cold). For good measures I'll be replacing all the vacuum lines. Might be time to fix or replace the MPS. Anyways, it was great meeting all of you. Cant wait until next time. Thanks Mike Might want to check for a leaky decel valve if you have one or the adjustment. If it is cracked or leaky it will do this. Assuming you are running D-jet. Thanks for the feedback. I didn't even think of the decel valve. I'll check it in the morning. Are there any tricks to see if its working? Mike |
Lo-Fi Version | Time is now: 25th April 2024 - 10:22 AM |
