Front Suspension Jig, Has anyone used this jig?? |
Mitox |
Nov 11 2020, 02:40 PM
Member Group: Members Posts: 395 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States |
As my ultra slow restoration pro-gres-ses, I've found a front suspension jig available from Stoddard.
Has anyone here had any experience with this jig? It seems like a good tool to ensure my "straightening" job is done correctly. https://www.stoddard.com/t52-1975.html |
billium01 |
Nov 11 2020, 09:48 PM
Member Group: Members Posts: 136 Joined: 12-April 13 Member No.: 15,764 Region Association: None |
Hi, I had some work done by a shop. They replaced my front trunk floor with this jig. Can't remember where I bought it. Probably was stoddard. Made things go smoothly from what I heard. Check out my build page here. I've got some photos of it in use.
http://www.914world.com/bbs2/index.php?sho...eauty&st=80 |
Nov 11 2020, 10:00 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If the repair is already done, I would just measure out the suspension points and make sure everything is in spec.
You can also put bolts into the threaded portions of the chassis, lay a straightedge across the bolts, measure and visually check to see if things look right in the different dimensions. The jig is really to hold things in place while you weld. |
Lo-Fi Version | Time is now: 9th May 2024 - 03:51 AM |
