2.0 or more, Bigger is better |
930cabman |
Nov 14 2020, 05:07 PM
Advanced Member Group: Members Posts: 3,000 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I cut my wrenching teeth on VW bugs and Type 3's back in the '70's and '80's. Been somewhat out of the game for several years looking to rejoin into the 914 world. Generally the easiest way for more kick is to increase displacement. Short of going to turbo's what is available as far as big bore kits. I am not interested in going the 6 cylinder route or chevy small block route. The car will be street only, but I need speed.
Bleyseng |
Nov 15 2020, 09:29 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
New 2.0L AA casting are reworked by Len with all new parts. Roughly $1700 for a set which I am running myself in my 2056 engine. I have 44x38 valves too
DRPHIL914 |
Nov 15 2020, 10:03 PM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
New 2.0L AA casting are reworked by Len with all new parts. Roughly $1700 for a set which I am running myself in my 2056 engine. I have 44x38 valves too how much more hp with len’s heads and the 2057 set up with d-jet? i can tell you after my first a/x weekend that while the 914 handed far better than most of the hot hatches there this weekend they best me by 5 sec or so and it has so much to do with the quick acceleration out of the corners, which i was sorely lacking—. very i interested in doing this by next weekend. i can run SCCA heritage , even with the 2056 as long as the case is the original stock case, can’t turbo it. |
Bleyseng |
Nov 15 2020, 10:49 PM
New 2.0L AA casting are reworked by Len with all new parts. Roughly $1700 for a set which I am running myself in my 2056 engine. I have 44x38 valves too how much more hp with len’s heads and the 2057 set up with d-jet? i can tell you after my first a/x weekend that while the 914 handed far better than most of the hot hatches there this weekend they best me by 5 sec or so and it has so much to do with the quick acceleration out of the corners, which i was sorely lacking—. very i interested in doing this by next weekend. i can run SCCA heritage , even with the 2056 as long as the case is the original stock case, can’t turbo it. I set my car up for AXing and track use in 2004. The 120hp is nice but installing a shorter 3rd and 4th gears made the difference plus being able to rev to 6000 rpms. BUT a 914 in AXing isn’t about acceleration but carrying speed thru the corners. Money spent on suspension upgrades and tires makes a huge improvement |
Superhawk996 |
Nov 16 2020, 07:35 AM
914 Guru Group: Members Posts: 5,726 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
. . . AXing isn’t about acceleration but carrying speed thru the corners. Money spent on suspension upgrades and tires makes a huge improvement (IMG:style_emoticons/default/agree.gif) I used to AX my Miata as SCCA C street (stock) level in the 90s. Had the opportunity to ride with former SCCA Nationals winner driving my car. It was humbling. There was ton's of time left in my car. All about the driver, technique, and maintaining momentum. And that was with my lard (IMG:style_emoticons/default/bootyshake.gif) as dead weight in the car too! 914's are no different. |
DRPHIL914 |
Nov 16 2020, 08:09 AM
. . . AXing isn’t about acceleration but carrying speed thru the corners. Money spent on suspension upgrades and tires makes a huge improvement (IMG:style_emoticons/default/agree.gif) I used to AX my Miata as SCCA C street (stock) level in the 90s. Had the opportunity to ride with former SCCA Nationals winner driving my car. It was humbling. There was ton's of time left in my car. All about the driver, technique, and maintaining momentum. And that was with my lard (IMG:style_emoticons/default/bootyshake.gif) as dead weight in the car too! 914's are no different. no doubt i have a lot to learn!!! i am sure there is a some more time in the car and a few tweaks to be made . i let an instructor drive the car for a run and he was not used the the long throw of the clutch in a 914, but i watched his line and how he came thru several turns and braking points etc., so then my next run was much faster, inf fact i ran faster than he did, but that is just me knowing my car better than him. if he took it out for 3-4 more runs no doubt he would have knocked off a good 5-6 seconds i am sure. - hey i went out to learn and get a better feel for what the car can do, it’s very tight and well balanced, with the sport bilistein and 205/55-16 on 7” rear and 6” front, it’s super tight. i never slid or lost traction in front, just the rear on a couple tight corners, came in too tight on wrong line, but it comes back fast, i never felt like i was going to spin out or loose it, but i could feel towards the last run i was getting a good feel of how far i could push it. being only 3-4 seconds behind a couple of the mazda’s , bmw and suby in our novice class and looking at the times of the fret class drivers i can see it could be competitive looking forward to seeing home much i can improve next year with learning how to adjust the suspension etc, like, if i dropped the rear one notch it would add an extra degree of negative camber and i think i could hold those tight corners a bit better. any other suggestions are welcome !! |
Lo-Fi Version | Time is now: 20th April 2024 - 04:29 AM |
