FS; 914 Bolt in roll cage |
Bates |
Nov 17 2020, 09:02 AM
Bates Group: Members Posts: 68 Joined: 27-December 13 From: Madison, Virginia Member No.: 16,800 Region Association: MidAtlantic Region |
Removed form my 914-6. Roll cage in good condition with side diagonal bars.
It comes with all hardware, and new plates to weld onto car for bolt in. In very nice condition, not from a 'field found car', no rust, and all of the bars are marked so the existing bolts will line up when reinstalling. Yes; It fits with the Targa top on car, latches are a bit tight, but the top fits and is removable. Some padding is included. Cage has current Tech Sticker.... Located in Madison, VA. Local Pick up preferred. $750.00 for cage with new weld on pads. Window net option; $50.00 Attached image(s) |
porsha916 |
Nov 17 2020, 10:28 AM
Member Group: Members Posts: 214 Joined: 1-June 04 From: Greenwood, SC Member No.: 2,137 Region Association: None |
Removed form my 914-6. Roll cage in good condition with side diagonal bars. It comes with all hardware, and new plates to weld onto car for bolt in. In very nice condition, not from a 'field found car', no rust, and all of the bars are marked so the existing bolts will line up when reinstalling. Yes; It fits with the Targa top on car, latches are a bit tight, but the top fits and is removable. Some padding is included. Cage has current Tech Sticker.... Located in Madison, VA. Local Pick up preferred. $750.00 for cage with new weld on pads. Window net option; $50.00 Do you have any interest in a trade? 914 (Parts/Chassis) (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 12:53 AM |
