Engine turnover, Looking at possible purchase |
EJP914 |
Nov 17 2020, 04:09 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Hi,
I am looking at a pretty rust free '73 with a 1.7 engine. Car has been sitting for about 4-5 years without starting it. I don't suppose the engine is seized up from all that time sitting, but any suggestions on how to turn it over by hand to see if it still moves? Read somewhere to put the car in 5th gear and attempt to push it forward. Would that work or is there a better way? Thanks for the help. Ed |
Spoke |
Nov 27 2020, 08:24 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The picture of the door jamb looks good; very good. Almost too good. The fender seam ends about and inch before the bottom of the fender. Might be bondo?
Need to look at the hell hole under the battery and the jack points. If you look at the car again, ask to jack it up using the jack points; see if they are solid. About the 1.7L engine, I would advise against it. If you're going to look for an engine, look for a 2L or larger. I bought a 2.056L with dual carbs from Brad Mayeur for less than that. Having owned a 1.7L, 1.8L, 2L, and 2.056L, go for the 2L or larger engine. The power difference will transform the car. With the 1.7/1.8L, I could out drag a fully loaded semi-truck from a red light. With the 2/2.065L, I could keep up with some of the lower powered cars of today. |
Lo-Fi Version | Time is now: 24th April 2024 - 05:07 AM |
