Engine drop |
Engine drop |
dumbjim |
Nov 18 2020, 10:51 PM
Newbie Group: Members Posts: 25 Joined: 21-June 05 From: st.louis mo. Member No.: 4,312 |
Are there any good step by step tutorials that explaine how to drop your engine in your home garage without a lift? Thanks in advance
AZBanks |
Nov 19 2020, 08:58 PM
Senior Member Group: Members Posts: 1,057 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
TEP on floor jack. ROCK Solid!
Attached thumbnail(s) |
TX914 |
Nov 19 2020, 10:04 PM
Alan-B Group: Members Posts: 167 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
TEP on floor jack. ROCK Solid! That’s nice work @AZBanks . My craftsman jack had a similar horizontal pin that would not allow the TEF to sit down in the hole. I removed the pin and got a couple of carefully measured bolts to us in its place. That was a tip from Chris at Tangerine. |
Stltri |
Nov 20 2020, 09:38 AM
Member Group: Members Posts: 70 Joined: 13-April 15 From: SoCal Member No.: 18,622 Region Association: None |
TEP on floor jack. ROCK Solid! That’s nice work @AZBanks . My craftsman jack had a similar horizontal pin that would not allow the TEF to sit down in the hole. I removed the pin and got a couple of carefully measured bolts to us in its place. That was a tip from Chris at Tangerine. Can you provide the Craftsman jack model number? Most new floors jacks including all the Harbor Freight ones do not have a hole big enough to accomodate the Tangerine Plate bottom bar. |
ChrisFoley |
Nov 20 2020, 11:04 AM
I am Tangerine Racing Group: Members Posts: 7,911 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Can you provide the Craftsman jack model number? Most new floors jacks including all the Harbor Freight ones do not have a hole big enough to accomodate the Tangerine Plate bottom bar. The HF jacks have a removable swivel plate that is held in place by a big allen shoulder screw (hidden under the rubber pad). My newer engine lift plates are designed to be held in place with that shoulder screw. |
Lo-Fi Version | Time is now: 29th April 2024 - 08:52 PM |
