Engine drop |
Engine drop |
dumbjim |
Nov 18 2020, 10:51 PM
Newbie Group: Members Posts: 25 Joined: 21-June 05 From: st.louis mo. Member No.: 4,312 |
Are there any good step by step tutorials that explaine how to drop your engine in your home garage without a lift? Thanks in advance
AZBanks |
Nov 19 2020, 08:54 PM
Senior Member Group: Members Posts: 1,057 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
I agree on the Tangerine Engine Plate. (TEP)
I modified TEP to make it work better with my floor jack. I also modified the stock floor jack plate. The floor jack plate was originally mounted to the jack in a way that wasn't meant to be removed. I modified it to be removable so I can swap the TEP. The hole where the original plate mounted was not big enough for the solid cylinder stick down from the bottom of the TEP. I enlarged it to fit the TEP cylinder and then dirlled, cut and shaped the TEP cylinder to fit over the hoirizontal bar in the floor jack. The pictures should tell the story better than words. I wish I had pictures before the modifications. Original jack plate with black rubber insert. |
Lo-Fi Version | Time is now: 26th April 2024 - 07:27 PM |
