Engine drop |
Engine drop |
dumbjim |
Nov 18 2020, 10:51 PM
Newbie Group: Members Posts: 25 Joined: 21-June 05 From: st.louis mo. Member No.: 4,312 |
Are there any good step by step tutorials that explaine how to drop your engine in your home garage without a lift? Thanks in advance
TX914 |
Nov 19 2020, 08:04 PM
Alan-B Group: Members Posts: 167 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
Put everything you take off in containers so you don’t lose anything and label if any doubt. After several days with the engine out you will forget things! Also, Plan to spend half your time cleaning stuff.
AZBanks |
Nov 19 2020, 09:01 PM
Senior Member Group: Members Posts: 1,057 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Put everything you take off in containers so you don’t lose anything and label if any doubt. After several days with the engine out you will forget things! Also, Plan to spend 90% of your time cleaning stuff. FIFY Dropping the motor doesn't take much time. It is the cleaning of all the old oil, dirt, and grease that takes 90% of the time the first time you do this job. If you stay up on the maintenance and don't let it get filthy again, you can drop it in a couple hours the next time. These are specifically designed to be written on so they are great for storing small parts you take off. https://www.amazon.com/Lansinoh-Breastmilk-...1634&sr=8-4 |
Lo-Fi Version | Time is now: 26th April 2024 - 02:32 PM |
