Engine drop |
Engine drop |
dumbjim |
Nov 18 2020, 10:51 PM
Newbie Group: Members Posts: 25 Joined: 21-June 05 From: st.louis mo. Member No.: 4,312 |
Are there any good step by step tutorials that explaine how to drop your engine in your home garage without a lift? Thanks in advance
AZBanks |
Nov 19 2020, 08:58 PM
Senior Member Group: Members Posts: 1,051 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
TEP on floor jack. ROCK Solid!
Attached thumbnail(s) |
TX914 |
Nov 19 2020, 10:04 PM
Alan-B Group: Members Posts: 167 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
TEP on floor jack. ROCK Solid! That’s nice work @AZBanks . My craftsman jack had a similar horizontal pin that would not allow the TEF to sit down in the hole. I removed the pin and got a couple of carefully measured bolts to us in its place. That was a tip from Chris at Tangerine. |
Stltri |
Nov 20 2020, 09:38 AM
Member Group: Members Posts: 70 Joined: 13-April 15 From: SoCal Member No.: 18,622 Region Association: None |
TEP on floor jack. ROCK Solid! That’s nice work @AZBanks . My craftsman jack had a similar horizontal pin that would not allow the TEF to sit down in the hole. I removed the pin and got a couple of carefully measured bolts to us in its place. That was a tip from Chris at Tangerine. Can you provide the Craftsman jack model number? Most new floors jacks including all the Harbor Freight ones do not have a hole big enough to accomodate the Tangerine Plate bottom bar. |
TX914 |
Nov 20 2020, 10:56 AM
Can you provide the Craftsman jack model number? Most new floors jacks including all the Harbor Freight ones do not have a hole big enough to accomodate the Tangerine Plate bottom bar. @Stltri , I'm using a Craftsman 2-ton model 50239 - aluminum and fairly low profile. Perfect for the 914 but a little lite for my 4x4. Pictured also are the bolts I'm using in place of the pin for the Tangerine plate - 9/16 12-1 1/2G8 I believe with a nylon washer, but check. Could not get a nut on the back side so I hammered the threads flat on the upper portion so they would not move with weight on them. Worked fine. Attached image(s) |
Stltri |
Nov 20 2020, 11:52 PM
Can you provide the Craftsman jack model number? Most new floors jacks including all the Harbor Freight ones do not have a hole big enough to accomodate the Tangerine Plate bottom bar. @Stltri , I'm using a Craftsman 2-ton model 50239 - aluminum and fairly low profile. Perfect for the 914 but a little lite for my 4x4. Pictured also are the bolts I'm using in place of the pin for the Tangerine plate - 9/16 12-1 1/2G8 I believe with a nylon washer, but check. Could not get a nut on the back side so I hammered the threads flat on the upper portion so they would not move with weight on them. Worked fine. Thanks. Looks like a discontinued Craftsman model, not sure which ones will accomodate the bottom bar, which I have on my Tangerine plate. Like Chris said, the newer version does not have the bottom bar but instead can be bolted on most newer floor jacks. |
Lo-Fi Version | Time is now: 17th April 2024 - 08:17 PM |
