Black Friday/close out muffler sale |
mb911 |
Nov 19 2020, 07:25 AM
914 Guru Group: Members Posts: 6,855 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Guys and Gals
It has come a time for me to evaluate and grow the business. I have decided to close out my quiet technology mufflers. They are fantastic mufflers but very expensive to sit on parts/components in preparation to sell a completed muffler based off of my build to order business model. I am going to make a run of them based off of sales over the next 2 weeks and then they will become NLA. Please note I will still have plenty of options as I have new 914-6 heat exchangers,1.7 ,2.0 914-6 mufflers all available along with all my other products.. So here is how this will shake out 914-6 quiet muffler $550 (stock tail pipe) 914 2.0 quiet muffler $600(stock tail pipe) Payment can be made by check or paypal with you paying fees. Shipping is typically $40-$45 GT style bracket, hardware, and gaskets will be $60 with purchase of mufflers. Please note that the picture is for showing some of my products. This offer is for stock outlet only Thanks for all of your support.. This has been a challenging year for everyone and I have never forgotten all the support I have received from all of the people in the 914 community |
mepstein |
Jan 4 2021, 06:50 PM
914-6 GT in waiting Group: Members Posts: 19,284 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Once you remove the stock muffler hanger, put the gt hanger on the two trans studs. It really only fits one way. Then bolt the muffler to the heat exchangers and strap the muffler to the gt hanger.
TX914 |
Jan 5 2021, 02:26 PM
Alan-B Group: Members Posts: 168 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
Once you remove the stock muffler hanger, put the gt hanger on the two trans studs. It really only fits one way. Then bolt the muffler to the heat exchangers and strap the muffler to the gt hanger. Oh so you don’t use the stock hangar any more... guess I assumed the GT bracket would be in addition to. I suppose then one should support the heat exchangers until bolted to the muffler... |
bbrock |
Jan 5 2021, 04:57 PM
Once you remove the stock muffler hanger, put the gt hanger on the two trans studs. It really only fits one way. Then bolt the muffler to the heat exchangers and strap the muffler to the gt hanger. Oh so you don’t use the stock hangar any more... guess I assumed the GT bracket would be in addition to. I suppose then one should support the heat exchangers until bolted to the muffler... I'm planning to use the stock hanger. There's no reason it won't work. The HEs are still going to be in the same place they've always been and the muffler has to bolt to them. Just to clarify, I"m using the stock hanger INSTEAD of the GT hanger. |
mb911 |
Jan 5 2021, 05:07 PM
Once you remove the stock muffler hanger, put the gt hanger on the two trans studs. It really only fits one way. Then bolt the muffler to the heat exchangers and strap the muffler to the gt hanger. Oh so you don’t use the stock hangar any more... guess I assumed the GT bracket would be in addition to. I suppose then one should support the heat exchangers until bolted to the muffler... I'm planning to use the stock hanger. There's no reason it won't work. The HEs are still going to be in the same place they've always been and the muffler has to bolt to them. Just to clarify, I"m using the stock hanger INSTEAD of the GT hanger. The reason I suggest against that is because the muffler body is not supported in anyway and thus making it a lever and with the body of the muffler only .040 thick will likely work harden the welds and Crack at some point. I completely disagree with the engineering decision porsche made with stock system. The 911 setup is so much better. |
Lo-Fi Version | Time is now: 24th May 2024 - 02:21 PM |
