SOLD: 2.0 74 GA Engine |
nditiz1 |
Nov 22 2020, 12:42 AM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
****This one is sold and traveling to North Cali****
As some of you may have read I was having cooling issues with this engine. Come to find out it had a poor leak down blowing past where the heads meet the cylinders. While I could rebuild/refresh the top end or even just the heads I am going a different route and into a 6. The compression numbers were all around 125 - 130. It ran smooth and scooted down the road, but temps would start to rise (CHT installed). I'm selling this engine as is. It could use the following to get it to healthy status: Pushrod seals at the least - I was going to do tubes and seals Machine heads and or cylinders to create a better seal - could do just a whole top end with AA piston parts OR even bump it up to a 2056 Exhaust studs need to be replaced - I think 1 even broke when removing the exhaust Intake - I had dual dellorto's, but also put on dual webers. Both were great Exhaust - needs it all Thermostat I have the complete unmolested 2.0 engine tin. As well as the rocker shafts/rockers/pushrod spring clip etc. for the open side. If I get the asking price I will throw in a good used thermostat with a new cable. Can put it on a pallet. I'm in MD. The last 2.0 I sent to CA was around $350 I believe. $1000 + shipping (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1606027363.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1606027364.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1606027364.3.jpg) |
sfspeed |
Nov 22 2020, 05:39 PM
Newbie Group: Members Posts: 9 Joined: 26-April 20 From: SF Member No.: 24,184 Region Association: Northern California |
PM sent
Lo-Fi Version | Time is now: 20th April 2024 - 05:59 AM |
