What 'obvious' 914 thing did you not know?, I was a 914 owner for X number of years before I found out..... |
orthobiz |
Nov 25 2020, 12:30 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
25 years since buying my first teener, I've still not figured out the heater controls without having to put my reading glasses on to figure which lever to move in which direction to defrost the windscreen (sorry, windshield...). Brad Mayeur told me, after owning these since the 70's, that the upper two slide levers adjust the cold and the lower two (slider and the floor pull switch) adjust the heat. Good to know when you're driving an early car with the hieroglyphics derived from antiquity (the Fifth Element makes more sense). Paul |
orthobiz |
Nov 25 2020, 12:31 PM
There's a driver pocket on the longs for the seatbelt when not in use.
Paul |
mmichalik |
Nov 25 2020, 12:37 PM
MikeM Group: Members Posts: 697 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
Took me years to realize that you could reset the trip odometer. I still can't figure that one out on my '74 (IMG:style_emoticons/default/smile.gif) |
Ansbacher |
Nov 25 2020, 12:47 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Took me a year (until Sahara Beige Steve) told me that my stock side mirrors could be swiveled backwards flush with the body. Thanks Steve!
BTW- this is a very useful thread of Easter Eggs. Ansbacher |
Jim C |
Nov 25 2020, 12:50 PM
Member Group: Members Posts: 190 Joined: 11-July 19 From: Texas Member No.: 23,294 Region Association: Southwest Region |
brcacti |
Nov 25 2020, 12:53 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
I had a 914 in 83-84 sold it then got another in 2019, did not know LE's existed until 2019-2020. Did not know until my second car just how important is it to keep clean grounds on these cars, also did not know they were mad out of non galvanized metal.
ClayPerrine |
Nov 25 2020, 12:56 PM
Life's been good to me so far..... Group: Admin Posts: 15,443 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
ClayPerrine |
Nov 25 2020, 12:59 PM
Took me years to realize that you could reset the trip odometer. I still can't figure that one out on my '74 (IMG:style_emoticons/default/smile.gif) There is a knob under the dash to the left of the steering wheel. Make sure you are parked, then turn the knob. It will rotate the numbers on the trip odometer. And guys.. if you post something, please say how to do it. This will help others out. |
DRPHIL914 |
Nov 25 2020, 01:17 PM
Took me years to realize that you could reset the trip odometer. I still can't figure that one out on my '74 (IMG:style_emoticons/default/smile.gif) There is a knob under the dash to the left of the steering wheel. Make sure you are parked, then turn the knob. It will rotate the numbers on the trip odometer. And guys.. if you post something, please say how to do it. This will help others out. knob could be gone, and the cable it’s attached to might not be in place, i had to go hunting for mine, it was attached to the back of the speedometer but not thru the hole in the dash knee pad, knob was gone. |
eric9144 |
Nov 25 2020, 01:23 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
I learned early on that if you need to transport something 'big' you can take the spare tire out of the front trunk along with its screw in 'hold down' and it can be put in the rear trunk and secured using the same 'hold down' giving you a fully usable space in the front. There's a threaded nut in the rear trunk and I want to say there's even a grommet in the trunk carpet for this...
(IMG:style_emoticons/default/beerchug.gif) |
Betty |
Nov 25 2020, 02:08 PM
Driver Group: Members Posts: 511 Joined: 10-December 04 From: Hurst, TX Member No.: 3,255 Region Association: South East States |
Betty |
Nov 25 2020, 02:11 PM
I had my car for years before I found out there was:
#1 - A light in the engine compartment, and... #2 - That light in the engine compartment is supposed to stay on all the time when the park lights are on. |
Jamie |
Nov 25 2020, 02:47 PM
Senior Member Group: Members Posts: 1,031 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
And how many of us wanting to add a passenger side rear view mirror searched long and hard for that "rare" right side mirror?
fixer34 |
Nov 25 2020, 07:09 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Took me years to realize that you could reset the trip odometer. I still can't figure that one out on my '74 (IMG:style_emoticons/default/smile.gif) There is a knob under the dash to the left of the steering wheel. Make sure you are parked, then turn the knob. It will rotate the numbers on the trip odometer. And guys.. if you post something, please say how to do it. This will help others out. knob could be gone, and the cable it’s attached to might not be in place, i had to go hunting for mine, it was attached to the back of the speedometer but not thru the hole in the dash knee pad, knob was gone. The knob on my -6 is on the RIGHT side of the steering wheel. No dash knee pad. |
siverson |
Nov 25 2020, 08:15 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Took me several years to realize that the seat/pedals/steering wheel are all offset and nothing is square. Apparently on purpose.
-Steve |
Maltese Falcon |
Nov 25 2020, 09:07 PM
Advanced Member Group: Members Posts: 4,641 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
...that after 1 year of ownership; you Can turbo a 914 (IMG:style_emoticons/default/driving.gif)
And...after 2 years of street driving with water/meth injection; I found out that at the loong Riverside Raceway (with the POC) that tank runs out quick, which led to an expired T4 engine. I then learned that I could convert to six cylinder 911 power & still learning things about the 914 today (IMG:style_emoticons/default/biggrin.gif) |
914e |
Nov 25 2020, 09:17 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I learned even in the Arizona desert a 914 can rust.
VegasRacer |
Nov 25 2020, 09:20 PM
ELVIRA Group: Benefactors Posts: 8,506 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
The left and right sun visors are not the same. The passenger side is supposed to have a vanity mirror.
A floppy visor can be easily fixed by tightening the screw at the center post. |
HansJan |
Nov 25 2020, 09:44 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Took me years to realize that you could reset the trip odometer. I still can't figure that one out on my '74 (IMG:style_emoticons/default/smile.gif) There is a knob under the dash to the left of the steering wheel. Make sure you are parked, then turn the knob. It will rotate the numbers on the trip odometer. And guys.. if you post something, please say how to do it. This will help others out. knob could be gone, and the cable it’s attached to might not be in place, i had to go hunting for mine, it was attached to the back of the speedometer but not thru the hole in the dash knee pad, knob was gone. The knob on my -6 is on the RIGHT side of the steering wheel. No dash knee pad. This better be some sort of joke, to get idiots like me to go nuts looking for this knob. Sounds like blinker fluid to me... Good one guys (IMG:style_emoticons/default/smile.gif) |
Mike Bellis |
Nov 25 2020, 10:00 PM
I didn't know how slow they were. I never owned a T4 engine. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 10th May 2024 - 09:45 PM |
