SOlD 911 Aluminum Calipers - $175 Loaded, 3.5 " hole Spacing , 44mm pistons |
bdstone914 |
Nov 25 2020, 11:34 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have a pair of 911 alumunum rear calipers. Not sure what car that are from. The hole spacing is 3.5" so they will fit on later 911 front struts with that spacing. They use up to a 24mm thick vented rotor. Piston size is 44mm compared to 36mm for stock 914.
Included are new Textar pads, spreader clips an SS pins. They could also be modified for radial mount for use front or rear. Please do your home work to see if they are a good choice for your car. Braking is a system that works best when properly setup. Price is $175 plus shipping. Attached thumbnail(s) |
rcotten951 |
Nov 25 2020, 01:27 PM
I'm new here ... Group: Members Posts: 0 Joined: 15-May 10 From: Crescent City, CAlifornia Member No.: 11,729 Region Association: Northern California |
PM sent I would like to buy them, THx - Russ
Lo-Fi Version | Time is now: 5th May 2024 - 08:32 AM |
