Throttle cable mount for IDF installs, * New Item * |
914werke |
Nov 28 2020, 11:27 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
For those cars who's induction has been swapped from the OE FI to twin carbs, how & where to mount the throttle cable has been an issue.
I've personally seen all manner of homemade mounts, some good, some down-right tragic! (IMG:style_emoticons/default/headbang.gif) This is the one style I found to be the best. (IMG:style_emoticons/default/smile.gif) Made of thick gauge steel it mounts to the case seam using (typically) stock hardware. Because of its ridged design it will not flex like so many others do. Since it mounts centrally you don't get uneven side loading of your linkage. Plated in gold zinc chromate it looks pretty good too! Available HERE (IMG:style_emoticons/default/aktion035.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 29th April 2024 - 10:24 AM |
