Window Seal Vertical install, 914 Rubber kit |
Nacho |
Nov 30 2020, 07:02 PM
Member Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None |
Happy post Thanksgiving everyone.
Im in the middle of installing new windows seals from 914Rubber and it seems most seals are larger that what they need to be. This is good as most 914 are not exactly the same. In the below picture am I supposed to cut the section of the vertical seal that goes beyond the aluminum retaining strip? Does my seal look installed in the correct orientation? |
Mikey914 |
Dec 1 2020, 10:35 AM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
PS yes your seal appears to be installed correctly.
Nacho |
Dec 1 2020, 11:42 AM
PS yes your seal appears to be installed correctly. Perfect and thank you for information much appreciated. (IMG:style_emoticons/default/beerchug.gif) Ignacio |
Lo-Fi Version | Time is now: 9th May 2024 - 05:50 PM |
