Window Seal Vertical install, 914 Rubber kit |
Nacho |
Nov 30 2020, 07:02 PM
Member Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None |
Happy post Thanksgiving everyone.
Im in the middle of installing new windows seals from 914Rubber and it seems most seals are larger that what they need to be. This is good as most 914 are not exactly the same. In the below picture am I supposed to cut the section of the vertical seal that goes beyond the aluminum retaining strip? Does my seal look installed in the correct orientation? |
rhodyguy |
Dec 1 2020, 12:59 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,061 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
If you pulled them thru the strip give them time to recover before cutting. Glycerin is a super lube for rubber items. For outer window scrapers, trim to fit after recovery and the end caps are put back on.
Lo-Fi Version | Time is now: 27th April 2024 - 08:03 AM |
