| Chaznaster |
Dec 2 2020, 08:28 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States
Hi. I have a ‘74 1.8 that is carbuerated. The PO did not have the oil pressure sensor (idiot light) connected. There is only a spade connector coming from the sensor. A lot of wires have been cut back. I read that the sensore wire is red/green. I presume that would be true at both ends (instrument panel and engine bay). Does anyone know where I should be digging to find it? Thanks!
| JeffBowlsby |
Dec 2 2020, 08:35 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,335 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
It is in the ignition harness. Goes to the relay board.
| Chaznaster |
Dec 3 2020, 06:21 PM
| JeffBowlsby |
Dec 3 2020, 06:29 PM
It goes to Pin #1 on the 12 pin connector All 914s are identical regarding this. See attached harness diagram specific to your 1974 1.8L harness. The pin #s are cast into the 12 pin connector housing.
Attached File(s)
HarnDia_IGN_74_75L_Jet.pdf ( 62.93k )
Number of downloads: 49 |
Lo-Fi Version | Time is now: 10th August 2026 - 08:52 PM |
