Original Dash Color, - were many yellow? |
altitude411 |
Dec 5 2020, 09:03 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
914_teener |
Dec 5 2020, 09:43 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Here’s another shot: My car was built in October 1972. It also has white headlight surrounds, which @Pete000 said was unlikely (but a little research proved otherwise I believe) and in all aspect seems very original. Is it possible they used red primer when they built this one? No...they didn't use red primer. It's been replaced at some point. |
Montreal914 |
Dec 5 2020, 10:00 PM
Senior Member Group: Members Posts: 1,544 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I would investigate a little more... (IMG:style_emoticons/default/sad.gif)
Are you sure your car was originally white? This front trunk and fender seemed to have been repainted. Have you pulled up your carpets to see the floor tar color? |
MM1 |
Dec 7 2020, 01:51 AM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
White floor. White everywhere-L80e on the tag.
Guess it had some panels. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/sad.gif) a bit shocked and disappointed-still a pretty straight and solid SoCal car according to the sticker and the records. Sawzall warming up now. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/lol-2.gif) Guess I should go ahead and add a front anti-sway bar so I can have more fun on the tight mountain roads I like to drive. . . What were original factory primer colors? |
Rob-O |
Dec 7 2020, 08:31 AM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
The car could’ve been repainted more than once. L80E originally from the factory, then red, then back to white.
burlybryan |
Dec 7 2020, 01:03 PM
Member Group: Members Posts: 102 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
Maybe we should put this in our signature line:
74 1.8 Saturn Yellow, Zambezi Green dash. Parts car 72 1.7 Alaska Blue, Signal Orange dash. |
simonjb |
Dec 7 2020, 01:28 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
My yellow car has a yellow Dash !! (IMG:style_emoticons/default/biggrin.gif)
pete000 |
Dec 26 2020, 10:36 AM
Interesting fined @MM1 I don't recall my Saturn yellow 74 having an odd colored dash. I believe it was yellow which sounds plausible. Your car might have received a factory replacement hood and fender in the OEM red primer back in the day, so perfectly correct repair with OEM Porsche parts. Interesting discovery in 914 weirdness. !
davep |
Dec 26 2020, 03:00 PM
914 Historian Group: Benefactors Posts: 5,137 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The removable dash section was painted and assembled separately from the body. The color coat was in whatever color happened to be available at the time; perhaps done during body color changes so as not to waste paint while flushing the guns. Then they had the flat black paint sprayed over the front and top faces.
The handwritten # on the underside of the dash is a production #. The production # and the Karmann body # (stamped on the paint badge and either stamped into the rear trunk floor or on a body tag riveted in the front trunk) are independent date codes, but for the 914/4 are almost 95% the same as one another. For some 35 years I thought they might be always the same, then I was able to get source for factory data and found a few that differed. Then I was able to prove the handwritten # was the production #, and the other was a Karmann body #. |
MM1 |
Dec 26 2020, 08:25 PM
Morph914 |
Dec 26 2020, 09:48 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
Al Meredith |
Dec 27 2020, 11:33 AM
Senior Member Group: Members Posts: 958 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I just checked my 914-6 # 1937 as the dash is out of it and it is painted ( over spray) the same color as the rest of the car , Tangerine . It also has a grease pencil # 1301952
colingreene |
Dec 29 2020, 01:09 AM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
My silver car the dash is light metallic blue.
Arno914 |
Dec 29 2020, 04:39 AM
Member Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany |
My 1971/4 is white L80E and I remember when pulling the dash some 30 years ago it was painted in blue with a handwritten note "Enzianblau"on it. Enzian is a flower of the alps an can be used to make some high octane booze. (IMG:style_emoticons/default/beer3.gif)
Back then I figured that maybe the factory used the dash panels to judge the look of new colours? (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1609238383.1.jpg) |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:08 AM |
