T4 Timing specs |
T4 Timing specs |
Charles Freeborn |
Dec 10 2020, 12:18 AM
Member Group: Members Posts: 244 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Interested in opinions on timing specs. Engine is 2.0 , 9.5:1 Euro pistons, big valves, Webcam 86b, IDF 44’s , headers,92 octane clear gas. ElectraMotive crank fired with adjustable settings for Initial, 3000 rpm, and 8000retard ( mine will never see 8k).
I’ve been told a variety of advice. Need the straight scoop. Thx. |
michael7810 |
Dec 10 2020, 08:01 AM
Senior Member Group: Members Posts: 1,079 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Find someone with VW experience and a dyno to tune the engine. You won’t regret it.
GregAmy |
Dec 10 2020, 11:40 AM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Yeah, but "finding someone with VW experience" is a tough one. For example, I've got lots of dyno opportunities up here in CT but most are Honda or 'Mercun experience.
I'd like to find out how far we can push this envelope, but I'd prefer to not use my own engines as the guinea pig... (IMG:style_emoticons/default/wink.gif) I tune my historics racer, roughly the same specs as yours except Mallory disty, to 32* total advance at 3000 RPM. On my dead-stock-engine street car using Microsquirt, I tickle the edges with 30-33 at max-RPM full throttle to as much as 36 at mid-throttle cruise to 40 at high-RPM mid-throttle. No clue if that's good or bad. But not really applicable to your engine specs, as this is truly a dead-stock 2L engine. |
michael7810 |
Dec 10 2020, 12:46 PM
Yeah, but "finding someone with VW experience" is a tough one. For example, I've got lots of dyno opportunities up here in CT but most are Honda or 'Mercun experience. I'd like to find out how far we can push this envelope, but I'd prefer to not use my own engines as the guinea pig... (IMG:style_emoticons/default/wink.gif) I tune my historics racer, roughly the same specs as yours except Mallory disty, to 32* total advance at 3000 RPM. On my dead-stock-engine street car using Microsquirt, I tickle the edges with 30-33 at max-RPM full throttle to as much as 36 at mid-throttle cruise to 40 at high-RPM mid-throttle. No clue if that's good or bad. But not really applicable to your engine specs, as this is truly a dead-stock 2L engine. Fair enough. I work at such a place and there are several in Phoenix. We set most engines at 30* total advance. |
brant |
Dec 10 2020, 01:10 PM
914 Wizard Group: Members Posts: 11,613 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Altitude and compression are important variables for timing
I change timing depending on the altitude of the track |
Charles Freeborn |
Dec 10 2020, 09:33 PM
Yeah, but "finding someone with VW experience" is a tough one. For example, I've got lots of dyno opportunities up here in CT but most are Honda or 'Mercun experience. I'd like to find out how far we can push this envelope, but I'd prefer to not use my own engines as the guinea pig... (IMG:style_emoticons/default/wink.gif) I tune my historics racer, roughly the same specs as yours except Mallory disty, to 32* total advance at 3000 RPM. On my dead-stock-engine street car using Microsquirt, I tickle the edges with 30-33 at max-RPM full throttle to as much as 36 at mid-throttle cruise to 40 at high-RPM mid-throttle. No clue if that's good or bad. But not really applicable to your engine specs, as this is truly a dead-stock 2L engine. Many thanks. I figured it was in the low 30's total. I'll start there and then see how it feels. |
Charles Freeborn |
Dec 10 2020, 09:35 PM
Altitude and compression are important variables for timing I change timing depending on the altitude of the track For all intents and purposes it will live most of it's life at sea level. There is one track that is at 2300' so I'd add or subtract a few degrees? The driveline was originally built and jetted for much higher altitude, so i've been wrangling with that to. I installed an AFR gauge so that has gotten easier. Modern tech, gotta love it.. |
Charles Freeborn |
Dec 10 2020, 09:38 PM
Find someone with VW experience and a dyno to tune the engine. You won’t regret it. There is a local shop with extensive experience, but their dyne is engine only, and their fees are stratospheric. The chassis dyno in town will bring no experience to the game. I've worked on these enough to know how to dial it, but doing the dyno pass, then climbing out to analyze data, do the tuning, getting back in for another run.... makes my brain, and my back hurt.. I'll give it some thought tho.. |
Lo-Fi Version | Time is now: 26th April 2024 - 11:47 AM |
