SOLD: 914 Parts Lot For Sale! $50 TAKE ALL! |
metalvolks |
Dec 20 2020, 01:23 PM
I'm new here ... Group: Members Posts: 0 Joined: 7-December 20 From: San Diego, CA Member No.: 24,961 Region Association: Southern California |
SOLD! SOLD! Hello everyone! Below is a complete list of 914 parts that I have for sale AS A LOT - I'm not really interested in parting pieces of it out any more.
I am looking to get $50 if you take everything listed below. I have hundreds of photos organized on a webpage with the link below. Everything sold as-is. Please take a look at the site before you contact me. Disregard the prices on the site. PICTURES OF ALL PARTS BELOW ARE HERE! http://paulmichaelrogers.com/porsche914parts/ Available Parts List: Engines/Engine Mechanical Parts: Engine Tin (1/2 Side Tin - 3 1.7/1.8, (4 Rear Tin), (Misc. Tin). Condition ranges from fair to good. Thermostat 2.0 Air Cleaner Housing - Surface Rust, but overall good condition Cooling Shroud (Good Condition) Muffler A/C Compressor (York) Stock (unknown condition) 1.7 (2 sets)/1.8/2.1 Cylinders (90 (2 sets) /92/96mm) - 92mm Cylinders and 96mm Cylinders SOLD, Pistons and Pins (most cylinders in good shape-all need to be honed. A few pistons have gouges and nicks. Pins would need to be polished) Pressure Plates Camshafts Crankshafts (Don't know for which motor) Engine Support Cross Bars - early style, later style 1.7 & ('74 1.8) Muffler Bracket Engine Electrical Parts: Engine Compartment Heater Blower Motor (TESTED-WORKING) 1 Alternator (with Cooling Vent) Interior/Mechanical: Shifter Seat Bracket Interior: Passenger Door Pulls Driver Door Pocket (Blue) A-Pillars - Poor to Fair Condition Ash Tray Driver Door Pocket Covers - Fair Condition Rear View Mirror - Fair Condition (Glass Issues) Upper Windshield Trim - Fair Condition Carpet Sill Trim Lot Seat Belt Receivers Misc. Interior Vents Dash Trim Plate - Very Straight Center Console Shifter Panel/Trim/Cover & Defrost Switch Console Box (Fair Condition) Body/Electrical: Tail Lights (2 lefts, 1 right) - Poor to Fair Condition (usable) Front Turn Signal Housings - Fair to Good Condition Horn Headlight Motors Headlight Assembly Lot - Fair Condition Fog Light Grill - Poor to Fair Condition (2 Cracks) A/C Evaporator, Fan and Enclosure DPD Misc. Relays, Switches, Actuators (Unknown Condition) Rear License Plate Lights Body: Rain Trays (2) - Both Have Small Cracks (can be fixed easily) License Plate Bracket Bumper Guards (Good Useable Condition) Spare Tire Well Section Brakes: Front Backing Plates - Good Condition Suspension: Aftermarket Unknown Brand Springs - Very High Spring Rate it Appears (Pair) Stock Rear Springs - 3 Red Stripes (2 Pair) Spring Hats, Seats & Hardware (Lot) Tie Rods Front Suspension, uprights, spindles, backing plates, crossmember Glass: 1969-1972 Driver's Window - Good condition Rear Glass - Good condition Misc.: Fuel Tank Fuel Tank Bumpers Windshield Washer Bottles Fuel Expansion Tanks (1 Plastic, 3 Metal) Charcoal Canister (2) Hood Springs and Hinges Factory Lug Wrench Thank you for looking! Paul SOLD parts list from this post: SOLD - OEM Oil Cooler - Good Condition - $40 SOLD - Cooling Shroud w/Alternator - Good Condition (small crack) - $40 SOLD - 2.0 Passenger Heat Exchanger - fair condition - $80 SOLD - 1.7/1.8 Stainless Steel Heat Exchangers (smoke tested ok) - Great Condition - $650 SOLD - 1.7 Long Block with heat exchangers (Complete Engine minus carbs, intake, distributor. Unknown Condition, Spins Freely - $450 SOLD - 1973 1.8 EC Case, Crank, Rods, Cam and Oil Pump - Good Condition - $200 SOLD - OE Oil Pump - 021 115 109A - $30 SOLD - 2.0 Oil Pickup and Windage - $40 SOLD - 1.7/1.8 Heat Exchangers (smoke tested ok) - Good Condition - Surface Rust and Paint, but solid - $150 SOLD - 1.8 Heads - Good Condition (No Visible Cracks) - 021 101 371 S - $120 (Set) SOLD - 2.0 Heads - Bare - 1 Head Great Condition (no cracks), 1 Head Machining Needed (Valve Seat Damage, 1 broken fin and 1 bent fin) - $250 (Pair) SOLD - Flywheel - $40 SOLD - Connecting Rods - $40 SOLD - Smog Pump - $40 SOLD - Engine Parts Lot1 (rocker arms, lifters, pushrods, springs, gaskets, etc) - $50 SOLD - Early 2.0 Muffler Bracket - $20 SOLD - Bosch Blue Coil - $20 SOLD - Pedal Board (Decent Condition) - $40 SOLD - 1973 914 Rolling Shell - Mainly surface rust. Hellhole, Rockers, Longs, Floors, Battery Tray, etc. solid. Small hole in floor, battery tray, spare tire well and trunk. Left Rear Shock Tower Needs Replacement. Has suspension, 5 steel "sport wheels", passenger windows and mechanism, etc. - $600 Engine Compartment Covers - $40 (white one is SOLD) SOLD - Engine Compartment Cover (Complete) With Rain Tray (Great Condition-No Dents) (Early Model) - $250 SOLD - Targa Top (Good-Usable Condition - small chip on corner - w/Front Latches) - $100 SOLD - Targa Top (Good Condition - w/ 1 Front Latch) - $125 SOLD - Front Hood (Great Condition - no dents, light surface rust, latch) - $125 SOLD - Dash Frame (Good Condition) - $80 SOLD - Front Bumper (Chrome Painted Black - Fair Condition) - Fairly straight with only a few dents- $80 SOLD - Rear Valance - poor to fair condition - $20 SOLD - Rear Calipers (Good Condition-Needs Rebuild) - $30/each SOLD - Rear Backing Plates - Fair Condition - $15/each SOLD - Weltmeister SP100 Rear Springs (Pair) - $60 SOLD - Wiper Arms Lot - $10 SOLD - 1 Alternator (with Cooling Vent) - $20 SOLD - Oil Filter Mounting Console - $15 |
rbzymek |
Mar 16 2021, 02:25 PM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
Greetings. Can you tell me about the mufflers? I need a stock muffler that will work with 2.0 SS HE's. Thanks.
metalvolks |
Mar 16 2021, 03:31 PM
Greetings. Can you tell me about the mufflers? I need a stock muffler that will work with 2.0 SS HE's. Thanks. Hi! I actually don't know which exhaust is for what, but, below is what I have. If your are interested in any of the parts listed in the ad, go to the website that hosts all the pictures of each part: https://paulmichaelrogers.com/porsche914parts/ (IMG:http://www.914world.com/bbs2/uploads_offsite/paulmichaelrogers.com-24961-1615930275.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/paulmichaelrogers.com-24961-1615930276.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/paulmichaelrogers.com-24961-1615930276.3.jpg) |
rbzymek |
Mar 16 2021, 03:50 PM
Greetings. Can you tell me about the mufflers? I need a stock muffler that will work with 2.0 SS HE's. Thanks. Hi! I actually don't know which exhaust is for what, but, below is what I have. If your are interested in any of the parts listed in the ad, go to the website that hosts all the pictures of each part: https://paulmichaelrogers.com/porsche914parts/ (IMG:http://www.914world.com/bbs2/uploads_offsite/paulmichaelrogers.com-24961-1615930275.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/paulmichaelrogers.com-24961-1615930276.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/paulmichaelrogers.com-24961-1615930276.3.jpg) Doesn't look compatible. Thanks. |
Lo-Fi Version | Time is now: 13th May 2024 - 03:37 PM |
