SOLD Restored Front Sway Bar $400 shipped in U.S., $400 shipped in U.S. |
bdstone914 |
Dec 26 2020, 12:28 PM
SOLD
I have an original front sway bar that is powder coated. All attaching hardware has been plated with yellow zinc. Bolts are higher 10.8 grade flange head bolts and nuts. Bushings for drop links are new. Bushings be installed. One triangular bracket id missing from the picture but is included. Sway bar bushing inserts are not pictured but are included. If your car did not have a factory sway bar you need to install the mounting brackets which requires cutting and welding to be done properly. There are several threads on front sway bar installation. If your car had a sway bar originally this is a bolt in job with every parts you need. $400 shipped in the U.S. Attached thumbnail(s) |
PaulFV8 |
Dec 26 2020, 01:28 PM
Member Group: Members Posts: 81 Joined: 2-August 20 From: Virginia, USA Member No.: 24,562 Region Association: None |
I’ll take it
Thanks Stay Safe |
Lo-Fi Version | Time is now: 18th May 2024 - 04:25 PM |
