Obtaining CAM shaft specs without disassembling the engine? |
GGerg1186 |
Dec 27 2020, 05:21 PM
Newbie Group: Members Posts: 15 Joined: 28-September 20 From: Dubuque IA Member No.: 24,724 Region Association: Upper MidWest |
I purchased a used 1.7L engine out of an autocross 914 car. Seller said it had a "performance cam" in it which could mean anything. Planning to pop a valve cover off with a dial indicator and the degree wheel on the front of the engine "spec" my cam. Should be able to get open, close, lift, and calculate duration. Should I put the dial indicator on the push rod side or the valve side of the rocker? Anyone had any success with identifying their cam without engine disassembly?
Next question, any way to determine compression ratio without removing the cylinder head? I am leaning towards removing the cylinder head just to see if I have cast or forged pistons & connecting rods. Ultimately, I want to know whether I can run regular pump gas, what max engine speed should be, and an appropriate carburation system to match the cam. Let me know your thoughts. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:58 PM |
