Speedometer cable routing, In-out-in-out? |
914sgofast2 |
Jan 5 2021, 08:06 PM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
What is the correct routing of the speedometer cable through the central tunnel? In at the firewall , then in the tunnel until the shift handle area where it runs across the top next to the wiring harness, then back into the tunnel to next emerge at the side of the bulkhead above the gas pedal area?
Lo-Fi Version | Time is now: 19th May 2024 - 07:44 PM |
