2270(or so) Build |
2270(or so) Build |
yeahmag |
Jan 8 2021, 12:47 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I'm starting to get the case(s) machined and inspected and parts ordered for my next generation engine. The car is mostly used for autocross.
78x96 96mm piston with 22mm wrist pin (stroker) 5.4" Type 1 Rod, 22mm wrist pin WebCam 86b/86c David Finch heads (from Len Hoffman many moons ago) 9.5:1 CR running on 91 octane pump gas CB Dry Sump (heavily modified) or Thorsten Piper dry sump pump Front mounted oil cooler There are a few crank options out there now: * DPR offset grind Type 1 journal * AA Performance Forged Type 1 journal * FAT Performance Forged Chevy journal I've read about a few 80mm DPR cranks breaking, so I was planning on staying under 80mm as I like the car to be able to rev. I was considering Chevy journals for ease of assembly, but the two cranks I've read about breaking were 80mm/Chevy journals. Is there any new information on cranks out there? Any input on the config? |
Mark Henry |
Jan 20 2021, 06:53 AM
You're worrying about the wrong thing, the crank is where you need to limit flex. I run and have built many engines with HD dual springs and I've never worried about the RC cam.
Jake Raby |
Jan 20 2021, 07:57 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
You're worrying about the wrong thing, the crank is where you need to limit flex. I run and have built many engines with HD dual springs and I've never worried about the RC cam. Same here. The reduced BC only calls for a little longer pushrods to be used as a negative.I have ran cams with a BC of 1" and one of them is still on the road now after 21 years. Its in my 356C. |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:53 AM |
