914-6 GT tribute prep for racing |
jhynesrockmtn |
Jan 9 2021, 11:36 AM
Member Group: Members Posts: 418 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I bought this car out of Livermore CA in 2018. It's a 6cyl GT Tribute built on a 73 4 cyl chassis with donor parts from a factory six. I know, wouldn't do that today most likely. It wasn't running at the time due to mostly sitting for years. After a refresh of the fuel system and carb rebuild (thanks Jack Morris) it fired right up. New brakes all around courtesy of PMB and new fuel system components from Tangerine Racing. Thanks vendors! A few drives and compression numbers seem excellent. 180-190 on all cylinders. I'm going to pull the motor now to do valve adjustment, belt change, etc.
While the motor is out I'm wondering about how best to prep to install the shoulder harnesses in a better way. You can see from the photos that there is one point through the rear firewall with no extra metal that holds the shoulder harnesses at this point. I'd prefer not to install a bar behind the seat on the cage due to wanting the seat to be able to go back as far as possible. I'll be mounting a Kirkey or OMP seat I already have. I'm 6-1 and pretty long legged. I'm thinking about welding plates to the rear firewall about the point you see the 3 plastic plugs currently and then put two eye bolts per side to mount the shoulder harnesses. The car will be used for some vintage race events and DE's. It was originally built for PCA solo events. Thoughts, advice, pics of your installs? Pic of engine compartment with existing eye bolt for harnesses Current drivers seat Passenger side with seat removed, same as driver's currently Gratuitous pics of car |
wndsrfr |
Jan 9 2021, 12:48 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Here's how I did it on my /4. Pay attention to the angle of the shoulder strap through the seat cutouts so best to mount the seat first. You'll also need to add a window net and a fire bottle within your reach. I'll post photos of the install on my /6 in a bit.
jhynesrockmtn |
Jan 9 2021, 01:55 PM
Here's how I did it on my /4. Pay attention to the angle of the shoulder strap through the seat cutouts so best to mount the seat first. You'll also need to add a window net and a fire bottle within your reach. I'll post photos of the install on my /6 in a bit. Thanks for the pic! That's roughly where I was thinking. Is there any benefit to welding the plate in that area vs. how it is show in your photo? I've got some work to do in figuring out which seat to use. I have a Kirkey with mounts that came out of a /4 I was going to race but passed that on to a buddy when I found this /6. I also have a couple of older OMP seats from a vintage 911 that was in an accident many years back and I bought some stuff off of it. I'm likely going to use the Kirkey and hopefully maintain the capability to mount stock seats if I want to use the car off of the track. I have a net to install and will figure out the fire system. I also need to wire in the cut off switch and do a bunch of other stuff before it is ready to be on track. |
wndsrfr |
Jan 9 2021, 02:49 PM
Here's the welded in plates on the /6 track car. You will want to mount the seat slam down on the floor in order to get the best angle for the shoulder belts to route--supposed to be no more than 15 degrees below horizontal IIRC. That will mean placing the eye bolts as near to the top as possible--I'm only 5'8" and mine just barely meets.
Lo-Fi Version | Time is now: 17th May 2024 - 01:25 AM |
