914-6 GT tribute prep for racing |
jhynesrockmtn |
Jan 9 2021, 11:36 AM
Member Group: Members Posts: 418 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I bought this car out of Livermore CA in 2018. It's a 6cyl GT Tribute built on a 73 4 cyl chassis with donor parts from a factory six. I know, wouldn't do that today most likely. It wasn't running at the time due to mostly sitting for years. After a refresh of the fuel system and carb rebuild (thanks Jack Morris) it fired right up. New brakes all around courtesy of PMB and new fuel system components from Tangerine Racing. Thanks vendors! A few drives and compression numbers seem excellent. 180-190 on all cylinders. I'm going to pull the motor now to do valve adjustment, belt change, etc.
While the motor is out I'm wondering about how best to prep to install the shoulder harnesses in a better way. You can see from the photos that there is one point through the rear firewall with no extra metal that holds the shoulder harnesses at this point. I'd prefer not to install a bar behind the seat on the cage due to wanting the seat to be able to go back as far as possible. I'll be mounting a Kirkey or OMP seat I already have. I'm 6-1 and pretty long legged. I'm thinking about welding plates to the rear firewall about the point you see the 3 plastic plugs currently and then put two eye bolts per side to mount the shoulder harnesses. The car will be used for some vintage race events and DE's. It was originally built for PCA solo events. Thoughts, advice, pics of your installs? Pic of engine compartment with existing eye bolt for harnesses Current drivers seat Passenger side with seat removed, same as driver's currently Gratuitous pics of car |
mlindner |
Jan 18 2021, 08:29 AM
Senior Member Group: Members Posts: 1,522 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
stownsen914 |
Jan 26 2021, 04:30 PM
Mlindner's approach could be an interesting one. A couple things to keep in mind:
Check the recommended spacing between shoulder straps. For HANS compatibility, I believe it may be recommended to have the mounts closer together than full shoulder width. Also, it might be a good idea to make sure the U bolts are at least 7/16" diameter threads. That's standard seat belt bolt diameter. And they should be graded bolts, like grade 5 at least. Common hardware store stuff is often grade 2. |
jhynesrockmtn |
Jan 26 2021, 04:38 PM
Mlindner's approach could be an interesting one. A couple things to keep in mind: Check the recommended spacing between shoulder straps. For HANS compatibility, I believe it may be recommended to have the mounts closer together than full shoulder width. Also, it might be a good idea to make sure the U bolts are at least 7/16" diameter threads. That's standard seat belt bolt diameter. And they should be graded bolts, like grade 5 at least. Common hardware store stuff is often grade 2. I'm going to test fit my seat in the next few days and once I'm comfortable I have that set I'll look closer as to how to mount the harnesses. I've got a lot of hardware from various mounts with DE cars and my old FV over the years. I need to go through those boxes. I'll post up some pics before I start drilling or welding :-) |
Lo-Fi Version | Time is now: 19th May 2024 - 12:14 PM |
