Electrical - Starting Issue |
FUEL14 |
Jan 11 2021, 03:55 AM
Member Group: Members Posts: 56 Joined: 11-August 18 From: Melbourne, Australia Member No.: 22,382 Region Association: Australia and New Zealand |
Hi, I have searched the forum for answers to starting issues, but I can't seem to find a thread for a problem exactly like mine.
The 3-year restoration of my car is about to come to an end, with a plan to be on the road early February. The wiring has been checked by a professional and modified/repaired where necessary. Everything was working great, starting no problem at all. But, just a couple of days ago, she turned over in the morning and didn't in the afternoon. Nothing was done to the car in between aside from a rear coilover adjustment. When I turn the key to the first position, I can hear the fuel pump whirring and all lights, horn etc work ok. But when I turn further to crank, all I get is a single click from the under-dash fuse box area. I installed a new battery as part of the restoration. The voltmeter is reading 13.4. Any ideas what might have gone wrong? Thanks in advance, Luke. |
ctc911ctc |
Jan 12 2021, 02:07 PM
Senior Member Group: Members Posts: 890 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
This is a very common problem, unfortunately, there are a few weak links.
1. The Ignition switch is susceptible to burning-out. The starter solenoid sucks a few more amps than the switch can handle. Some people add a relay at the starter to fix this problem. 2. Seat belt switch - unless you are going to Carmel, get rid of it. 3. Starter Solenoid - the bendix starter has many weird starter solenoid troubles. I went through 3 cheap ones before getting to one where it would start reliably. I have a writeup on this within 914 world. 4. Junction Box - behind the driver seat is a box with a plastic cover (held down with a nut on a long rod down the middle) where the engine hardnesses and the ignition harness come together. Corrosion can be a voltage stealer at this junction. Can steal the umph necessary to engage the starter solenoid. 5. Chassis Ground - Make certain that the ground strap is connected, clean, and tight. Many stories about these being 'part' of a larger problem. There are probably more, but that's what I got. CTC |
ClayPerrine |
Jan 13 2021, 09:13 AM
Life's been good to me so far..... Group: Admin Posts: 15,395 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
4. Junction Box - behind the driver seat is a box with a plastic cover (held down with a nut on a long rod down the middle) where the engine hardnesses and the ignition harness come together. Corrosion can be a voltage stealer at this junction. Can steal the umph necessary to engage the starter solenoid. Are you referring to the relay board? Clay |
Lo-Fi Version | Time is now: 20th April 2024 - 07:25 AM |
