Cylinder head temperature gauge |
Geezer914 |
Jan 13 2021, 03:53 PM
Geezer914 Group: Members Posts: 1,393 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
VDO no longer makes them, any other gauges out there?
mate914 |
Jan 14 2021, 09:32 AM
Matt Group: Members Posts: 739 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
If I may ask? Which spark plug do you install CHT probe on? I would like to know for both the six and four cylinders.
Thank you. |
Mark Henry |
Jan 14 2021, 09:57 AM
If I may ask? Which spark plug do you install CHT probe on? I would like to know for both the six and four cylinders. Thank you. /4 the #3 cylinder runs the hottest. /6 it doesn't matter as much, some say #1, some say #6....I used #1 just because it's the easiest to run to. Edit: For the /6 the #1 cylinder is the easiest for me to get to as I'm twin plug and I have a lift. I have my sensor on the lower #1 plug hole. On a standard 6 plug engine the 4/5/6 side may be easier to get to. This is important because you must take care not to twist or cut wires on plug install. On my six I cut/notched the plug hole seal for the CHT sensor wires. |
Lo-Fi Version | Time is now: 4th May 2024 - 01:50 PM |
