2 Pages V < 1 2
> Cylinder head temperature gauge
barefoot
post Jan 15 2021, 10:06 AM
Post #21
QUOTE(FlacaProductions @ Jan 14 2021, 10:07 PM) *
as i understand it - and i could be wrong - non-temperature compensated gauges will read out higher as the ambient temperature goes up and lower as it goes down. ie: if your engine temp is (for example) 250 at 72 degrees, a non-compensated display will show 260 at 82.
temp-compensated will show 250 no matter the ambient temp.
Not true, sorry.
Thermocouple based cylinder head temperature gauges use a bimetal construction that generates a voltage if one end is heated (or cooled). Thermocoulpes will measure the temperature DIFFERENCE between the hot end and the other end. Cold junction compensation introduces a measurement at the cold end then does an addition to read the actual temperature at the hot end, not just the difference.
i verified mine by placing the hot end in ~ boiling water as a bench test and got 210 degrees. Cooled to room temperature and the gauge read 73, so i know I'm reading actual head temps.
Hope this helps
narino
post Jan 15 2021, 03:44 PM
Post #22
QUOTE(aharder @ Jan 14 2021, 08:29 PM) *
I had a VDO for years and then it failed. I ended up with this one and I've been
pleased with it so far.
https://discountegauges.com/deg-cylinder-he...10-901-12-12ft/
Aharder - This gauge is nice! Looks a lot like the micro1000 from Aircraft Spruce that Jeff and Mark Henry posted. Does it take any 14mm TC? Or is it a specific connection?
Anyone know if the square bezel on the micro1000 can be removed to leave a circular gauge?
930cabman
post Jan 15 2021, 05:28 PM
Post #23
QUOTE(narino @ Jan 15 2021, 04:44 PM) *
Agreed, I will be lining up for this one. Thanks for posting
FlacaProductions
post Jan 15 2021, 07:01 PM
Post #24
QUOTE(barefoot @ Jan 15 2021, 08:06 AM) *
Not true, sorry.
Hope this helps
Perfect, thank you and my apologies.
One thing I hate is when untrue/wrong information is spread here and I hate that I'm part of doing so. Thanks for setting me - and the record - straight.
Krieger
post Aug 1 2022, 04:40 PM
Post #25
@Mark Henry did you need to make any modifications to the sensor to get it to fit on your six?
2 Pages V < 1 2
- Lo-Fi Version Time is now: 1st November 2026 - 01:20 AM
