Factory rear swaybar mounts |
partwerks |
Jan 13 2021, 08:01 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Any pictures of location where the factory rear swaybar backing plates, and "Z" shaped brackets get welded on?
This is on a 1975. |
914werke |
Jan 13 2021, 09:36 PM
"I got blisters on me fingers" Group: Members Posts: 9,995 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Pretty straightforward. There are two holes in the brace that spans the trunk floor.
They should have plastic caps in them but many have gone missing. The Weld nut fits up into that hole On the late cars you dont use the Z shaped bracket but a more simple Tang with weld nuts |
Chris914n6 |
Jan 13 2021, 09:40 PM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
75-76 doesn't get Z brackets or the reinforcement plate. That particular spot was changed for the bumper shock. It gets a flat plate with the 2 nuts in the precut 2 holes.
partwerks |
Jan 13 2021, 10:18 PM
Seems like in the past when I seen pictures, the backing plate was welded in the trunk, and the Z bracket goes on a stiffener on the bottom of the trunk??
https://duckduckgo.com/?t=ffhp&q=porsch...g&ia=images https://duckduckgo.com/?t=ffhp&q=porsch...g&ia=images https://duckduckgo.com/?t=ffhp&q=porsch...g&ia=images |
Chris914n6 |
Jan 14 2021, 01:17 AM
partwerks |
Jan 19 2021, 07:31 PM
They thought I had a 74, and sent me the wrong ones, but I guess I can just cut off the inner bend, and can continue from there.
Lo-Fi Version | Time is now: 18th April 2024 - 06:41 PM |
