Cylinder Head Temperature Sensor, 0 280 130 017 Readings |
dlee6204 |
Jan 16 2021, 12:07 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I recently acquired a NOS temperature sensor for the one year only '73 Djet system 0 280 130 017. This sensor has been NLA for a very long time and finding a used one is very difficult. Given the rarity there isn't a lot of information on the proper resistance values of this sensor. Pbanders (https://members.rennlist.com/pbanders/DJetParts.htm) lists three data points for the resistance of this sensor but I thought I would post my findings. I also listed the values of the aftermarket sensor 0 280 130 012 available from 914Rubber.
@Superhawk996 This answers some of your concerns. |
adolimpio |
Jan 23 2021, 10:37 PM
Art Group: Members Posts: 180 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
There was a suggestion to add a 2400 ohm resister in parallel to the 012 to make it equivalent to the 017 at 70 degrees. I added a third line to the chart to show what that would look like. Doesn't look like a good idea - running pretty lean a low temps!
Olympic 914 |
Jan 24 2021, 10:37 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
There was a suggestion to add a 2400 ohm resister in parallel to the 012 to make it equivalent to the 017 at 70 degrees. I added a third line to the chart to show what that would look like. Doesn't look like a good idea - running pretty lean a low temps! The Cylinder Head Temps rise pretty quickly from those low temps. And from 80deg on they are pretty close. with the parallel resistor I consider it a non-issue (JMHO) It really depends on your engine. I run a 1K resistor in parallel which theoretically should make my engine too lean at cold temps. But my wideband AFR tells a different story. My engine will not idle nicely immediately upon startup. but once I drive 1 mile it is warm enough to idle (In my case, by the second Stop sign.) One positive thing about the parallel resistor is if your CHT has a bad connection / failure, You engine will die on the spot. with the parallel resistor it will just go into a rich condition. You will still be able to drive on. I had this happen on the way home from Tennerpaluza. A little fiddling with the connection in the safety of a parking lot, instead of on the side of the road enabled me to remedy the problem and continue on. |
Lo-Fi Version | Time is now: 9th May 2024 - 04:32 AM |
