Cylinder Head Temperature Sensor, 0 280 130 017 Readings |
dlee6204 |
Jan 16 2021, 12:07 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I recently acquired a NOS temperature sensor for the one year only '73 Djet system 0 280 130 017. This sensor has been NLA for a very long time and finding a used one is very difficult. Given the rarity there isn't a lot of information on the proper resistance values of this sensor. Pbanders (https://members.rennlist.com/pbanders/DJetParts.htm) lists three data points for the resistance of this sensor but I thought I would post my findings. I also listed the values of the aftermarket sensor 0 280 130 012 available from 914Rubber.
@Superhawk996 This answers some of your concerns. |
nordfisch |
Jan 29 2021, 11:52 AM
Member Group: Members Posts: 86 Joined: 11-December 15 From: Germany Member No.: 19,451 Region Association: None |
Hi,
sorry for replying later than supposed... In the meantime I contacted Volker Huck from jetronic.org and asked him for values of the influence of the CHT resistance to the injection time. He didn't measure it up to this time. Said he had to do it using the specific ECU-type because they all react different. But he has the same opinion as we have - the difference between the sensors doesn't matter much because the engine head warms up rapidly in after a short time the sensors show almost the same values then. He reminded me there are values for the ...017-sensor in the German workshop- manual published by Bosch... I have to say the values from Bosch are meant without resistor and I tried to read out the values in my chart below from @Superhawk996 's graphic and from his chart. Please notice the sensor data published by Bosch is at different temperatures for the different sensors. I think, there is an error in the readings of the first 017 sensor <blue>. Magnifying the graph, I can see a double line, too... think I corrected the error in my chart. Regards Norbert |
Superhawk996 |
Jan 29 2021, 05:52 PM
914 Guru Group: Members Posts: 5,754 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
In the meantime I contacted Volker Huck from jetronic.org and asked him for values of the influence of the CHT resistance to the injection time. He didn't measure it up to this time. Said he had to do it using the specific ECU-type because they all react different. @nordfisch WOW that would be super interesting. Being able to correlate injector pulse time to the CHT with the specific ECU. It has been documented on the B. Anders site that the 73' ECU is a unique animal so I agree that it would need to be done with the MY73 ECU to get the right result. What is really interesting to think about is how a 70's vintage ECU gets "calibrated" in an era where that calibration was done by changing the physical analog circuits rather than putting 1's & 0's in memory! (IMG:style_emoticons/default/pray.gif) Although I do agree there is no practical difference in the sensors once at operating temperature I do have concerns and believe that there is such a significant difference in between 017 sensors and 012 sensors, that the starting, idle and warm-up could be pretty compromised with an 012 sensor in a 73' 2.0L ECU setup. I can't say this for sure as I have yet to assemble my 2.0L engine and to convert it to FI from carbs as I received it. I'm looking forward to trying both sensors though to help solve the riddle. Next up. I think i have 022 906 041A sensor that is also stamped 0 280 130 017 and yet I believe it reads more like a 012 sensor at ambient temp and cold temps. I need to dig it out and measure it and compare the the 012 curves that have just been documented. I belive there was a period of time where Bosch was transitioning the 1973 017 sensors and mistamped some 012's as 017's. |
Lo-Fi Version | Time is now: 27th April 2024 - 09:38 PM |
