Valve Train Question, One won't hold adjustment-- Knowledge Base Chime In |
Robarabian |
Jan 17 2021, 06:39 PM
914 A Roo Group: Members Posts: 591 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
A few weeks ago I posted a photo of some heads I pulled off a motor I had purchased from another member that had some heads with valves that were not in alignment with each other. They were GEX heads, and all the postings agreed, don't waste too much time on them. I saved them for another day.
I had a set of AA 2.0 heads (brand new) that were slated for another motor but this is a stop gap engine to use till that one is built. I swapped heads, cleaned everything, and re assembled. Valves adjusted and mounted to my test stand. Fresh oil, O rings etc... Engine fired quickly and got the webers to the point where it idled reasonably and I was going to start adjusting them. At about the three - four minute point of idling and goosing the throttle a bit, I heard a bit of valve train noise, almost like a "POP" and I could hear clickcty Clack so I shut it down. I set the crank back to TDC #1 and checked the valves. (cold) 1,2,4 were good. #3 the intake valve was out of spec so I re-adjusted. re-checked the other three again, rotated the motor through and buttoned it back up. This was a week or two ago. Today, I decided to tinker again and same thing happened. All was good, engine was running real smooth. Goosed the throttle, started tuning carbs and again, "POP". #3 is loose. When I say "loose" it is going from .006 adjusted to .008 so it is loud enough to hear. Putting it another way, it sounds as a proper air cooled type 4 should, and then clickety clack, loud valvetrain. Cyl's #1, 2, 4 are in spec. I am setting Intakes at .006 and exhaust at .008. I replaced all the valve adjuster tappets when I swapped the heads with stock ones, not swivels or anything weird. This one is baffling me. Could I have valve adjusters out of alignment? Is the head just going through a normal cycle of stretching new valves when it got to operating temp? Am I losing my mind? I appreciate the input from the knowledge base here. Im a garage mechanic, not a pro shop and Im only recently delving back into the mechanicals of the 2.0... |
burton73 |
Jan 18 2021, 07:05 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I am going to through this out. In 1979 I had a 1974 2.0 that I rebuilt and the vales kept going out of adjustment in a short amount of time. I readjusted it over and over each 200 miles or so. The problem was the lifters where not hardened by the factory that made them.
I had to take down the Eng. and found that the new cam and lifters had to changed because the lifters would mushroom. Very mad Maybe something like this is happening on just one of yours or some reason that the one may be wearing fast? Just putting this out there. All of my machine and balance work was done at a top shop. Bieker Engineering by Harry Bieker Bob B |
porschetub |
Jan 18 2021, 07:35 PM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I am going to through this out. In 1979 I had a 1974 2.0 that I rebuilt and the vales kept going out of adjustment in a short amount of time. I readjusted it over and over each 200 miles or so. The problem was the lifters where not hardened by the factory that made them. I had to take down the Eng. and found that the new cam and lifters had to changed because the lifters would mushroom. Very mad Maybe something like this is happening on just one of yours or some reason that the one may be wearing fast? Just putting this out there. All of my machine and balance work was done at a top shop. Bieker Engineering by Harry Bieker Bob B (IMG:style_emoticons/default/agree.gif) lifter and cam wear seem to be rather common on t4s,cam go's flat in the centre of the lobes and the lifters wear concaved and no rotation ,no favours to the rest of the valve train besides (IMG:style_emoticons/default/sad.gif) . Yes cam to lifter match is very important. |
Lo-Fi Version | Time is now: 15th May 2024 - 02:06 PM |
