Valve Train Question, One won't hold adjustment-- Knowledge Base Chime In |
Robarabian |
Jan 17 2021, 06:39 PM
914 A Roo Group: Members Posts: 591 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
A few weeks ago I posted a photo of some heads I pulled off a motor I had purchased from another member that had some heads with valves that were not in alignment with each other. They were GEX heads, and all the postings agreed, don't waste too much time on them. I saved them for another day.
I had a set of AA 2.0 heads (brand new) that were slated for another motor but this is a stop gap engine to use till that one is built. I swapped heads, cleaned everything, and re assembled. Valves adjusted and mounted to my test stand. Fresh oil, O rings etc... Engine fired quickly and got the webers to the point where it idled reasonably and I was going to start adjusting them. At about the three - four minute point of idling and goosing the throttle a bit, I heard a bit of valve train noise, almost like a "POP" and I could hear clickcty Clack so I shut it down. I set the crank back to TDC #1 and checked the valves. (cold) 1,2,4 were good. #3 the intake valve was out of spec so I re-adjusted. re-checked the other three again, rotated the motor through and buttoned it back up. This was a week or two ago. Today, I decided to tinker again and same thing happened. All was good, engine was running real smooth. Goosed the throttle, started tuning carbs and again, "POP". #3 is loose. When I say "loose" it is going from .006 adjusted to .008 so it is loud enough to hear. Putting it another way, it sounds as a proper air cooled type 4 should, and then clickety clack, loud valvetrain. Cyl's #1, 2, 4 are in spec. I am setting Intakes at .006 and exhaust at .008. I replaced all the valve adjuster tappets when I swapped the heads with stock ones, not swivels or anything weird. This one is baffling me. Could I have valve adjusters out of alignment? Is the head just going through a normal cycle of stretching new valves when it got to operating temp? Am I losing my mind? I appreciate the input from the knowledge base here. Im a garage mechanic, not a pro shop and Im only recently delving back into the mechanicals of the 2.0... |
Jake Raby |
Jan 18 2021, 11:42 PM
As a general rule, loose valves occur from cam/lifter wear, and tight valves occur from valves stretching, and seats moving.
What oil did you break it in on? What cam/lifters were used? What oil is it running now? |
Robarabian |
Jan 19 2021, 09:28 AM
Thanks Jake, always honored to have your expertise. The motor was someone else's, and I am trying to ensure it will run before putting it in the car. So it was a motor with approx 8,000 miles on it according to the seller, so I don't really know its internals, running dual weber 44's. I put 40's on it cause I think the 44's are overkill..96MM Jugs on a 1.8 crank. I noticed the heads were GEX when I popped the valve covers off to adjust the valves, and the valves were not sitting at the same height. So I swapped heads with some new ones (AA bolt ons) again, just as a temporary motor till I can do something more significant. Pistons looked clean, cylinders were not polished smooth. I pulled one lifter and it looked good. Cam didnt look scored looking through with a flashlight. Once the new heads were on, everything went back together smooth and then this little hiccup has occurred.
So my thought is that if I run it again next week and it happens again, then lifters / cam issue and the motor wont do what I had intended it to do and I have a rebuildable core... Valvoline High Zinc 20-50 As a general rule, loose valves occur from cam/lifter wear, and tight valves occur from valves stretching, and seats moving. What oil did you break it in on? What cam/lifters were used? What oil is it running now? |
Lo-Fi Version | Time is now: 15th May 2024 - 12:17 PM |
