washer schematic 1970 six, Plumbing correctly |
Speedo |
Jan 19 2021, 11:07 AM
Senior Member Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains |
Closing up the area in front of the bonnet. Heater blower installed and wondering what the washer plumbing looks like. I can find nothing in my manuals with a picture of the pump, wiring and plumbing to the squirters. If someone has their gas tank out, and can get some pics to help me install correctly...the washer pump, the reservoir, the lines to the squirters and the plumbing from the spare to the pump, and power feed from the harness.
Thanks! |
rgalla9146 |
Jan 22 2021, 06:28 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
If your car is an original six there are three holes above your passengers toes
The rubber mounts are pulled through those holes. If it is a conversion use the mount on your pump as a template for the mounting hole pattern. I can provide pump location diagram if you need it |
Speedo |
Jan 23 2021, 08:19 PM
If your car is an original six there are three holes above your passengers toes The rubber mounts are pulled through those holes. If it is a conversion use the mount on your pump as a template for the mounting hole pattern. I can provide pump location diagram if you need it I have an original six...pics or diagram would be helpful. Thanks for responding. (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 04:37 PM |
