3 Pages V < 1 2 3 >
> Out with the Megasquirt!, and in with....
GregAmy
post Jan 20 2021, 10:41 AM
Post #21
QUOTE(JamesM @ Jan 20 2021, 11:32 AM) *
You would have to ask @Eric_Shea about that one. His guys at PMB did the fabrication work for me as I didn't have the necessary tools to do it myself...
Understand.
I use the VAG IGN-4 ignitor/coil and it work great. However, my initial installation was on a steel plate I fabbed that sat across the disty retention stud and two engine tin screws. As the weather got hotter this Spring I started getting a lot of ignition cut-outs...short answer was the IGN4 was overheating, sitting on that plate mounted directly to the engine block.
Short term I moved it to sitting on top of the cooling fan, and I've yet to come up with an elegant replacement solution. I like yours and suggest that may keep the coil far enough away from the engine heat to allow air to circulate around it.
I've got an old 009 hanging about, might try fabbing something.
Porschef
post Jan 20 2021, 11:26 AM
Post #22
How you doin'
Greg, what about a phenolic block spacer, kinda like what was used under the runners at the heads... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/beerchug.gif)
JamesM
post Jan 20 2021, 11:57 AM
Post #23
QUOTE(BeatNavy @ Jan 20 2021, 04:02 AM) *
James, that's excellent. Thanks for posting this. I've got a small rat's nest in my setup as well, and I'm looking to clean it up with better wiring connections and routing. But I'm in the same sort of boat -- there's a tension between wanting to test something and improve it versus cleaning it all up and declaring it done and final!
One question: what model injectors are you using?
Again, looks great and thanks. Hopefully you do get some warm weather soon (IMG:style_emoticons/default/beer.gif)
It is hard to tear something out again when its working just fine. Little easier for me in this case in that the shortcomings of the d-jet harness were just becoming way to apparent. Once i get a tune on the new setup ill have to post a comparison of datalogs from the old and new systems as they are a night and day difference.
As for the injectors, they are an off the shelf part from FiveO Motorsports so no need to go sourcing anything used from a wrecking yard.
https://www.fiveomotorsport.com/a280-a380-h...-fuel-injector/
Lots of advantages over stock d-jet injectors, New(not 50 year old NLA parts) High impedance, Ev1 connectors, standard 3 bar pressure (try finding a good 2 bar d-jet pressure regulator these days) more reasonable flow rate (d-jet 2.0 injectors are pretty oversized) and probably my favorite part is that they come with documented flow data and more importantly, the voltage offset data. I was actually surprised at how low the dead time on these was when running at 3 bar. Knowing the proper dead time and voltage correction is critical for keeping the mixture consistant under varying system voltages. If you have issues with your idle dropping due to changing mixture when you turn on your headlights this may be why. I was so excited to test this that turning on the headlights was one of the first things i did once i got the idle mixture mapped in. No more idle dip! In theory someone could deduce the proper value for the d-jet injectors through trial and error, i just was never excited enough about doing that work.
After working on so many MS systems for myself and others I have developed a preferred list of hardware that I recommend, and these are my pick for use with stock intake runners if you want to eliminate any compromises.
Available in higher flow rate to if needed, or you can up the pressure as 3bar is the minimum spec on these.
JamesM
post Jan 20 2021, 12:52 PM
Post #24
QUOTE(GregAmy @ Jan 20 2021, 09:41 AM) *
Understand.
Heat is one concern I have in the back of my mind for sure with this coil setup but wont know what the end result will be until it warms up and I can get it out on the road. Like i said this coil pack setup is probably the most experimental part of this build so I cant yet speak to its reliability.
Assuming the coil you are running is the VAG 032 905 106B wasted spark coil? In the past I have had good results with when working with that pack however never tried it mounted where the stock distributor goes. The one issue I did observe though (and one of the reasons for trying something new) was some unusual/high rate plug wear. The plug had completely eroded the center electrode in less than a couple thousand miles. At the time I was not sure if it was due to a defective plug or the ignition system itself but after doing further reading it sounds like this is the nature of wasted spark coils due to the reverse polarity on half the plugs, band-aided by manufactures with the use of platinum plugs.
Curious if you re-checked your plug gaps after running the coil for a while now?
Also curious what your total dwell is when you are running? Wondering if excessive dwell may be contributing to excess heat in the coils? Wasn't able to find much specific information on either one of these packs around dwell requirements but information I was able to find on other VAG coils that was extracted from VW ECUs seems to indicate VW in general runs their coils with far less dwell than the suggestions I have seen on MS forums and manual.
Given this, I aimed on the lower end of the spectrum for the initial setup and am not seeing more than 2.8ms dwell when running after voltage corrections are applied and this value may even still be high based on the VW ECU tables I have seen where they are running roughly 1/2 of that. But again, no idea really as I have not been able to find any concrete documentation. Time/experimentation will tell. So far though the coil has been cool to the touch, granted this was only ran for about 20 minutes with no load with weather in the 30s. May be a different case when autocrossing when its 105 out.
One thing I considered doing when installing the pack in the first place was using spacers on the bolts between the coil and the mounting plate to allow air flow under the coil as i believe that is how some are mounted in the factory applications. Didn't have spacers on hand but i may go back and revisit that as well.
ill let you know how it turns out.
GregAmy
post Jan 20 2021, 02:19 PM
Post #25
QUOTE(JamesM @ Jan 20 2021, 01:52 PM) *
That's the one, and I have not re-checked spark gap. I wasn't aware of that erosion problem, but knowing that I'll check them; I've got about 2500 miles on the system so far.
When I was troubleshooting the cut-out issue I ended up backing off the dwell settings from where Mario (DubShop) recommended. I'm currently running Standard Dwell, 2.2ms Nominal, 1.0ms spark duration. Runs/starts quite good; I'm figuring it would work fine with less.
I have not dinkled with the battery corrections; it's at 88%@16V, 102%@14.0, 128%@12.0, 168%@10.0V. I'm running a Lithium battery so field voltage tends to run high, around 14.2-14.5V running.
It runs warm to the touch after dirivng for some time, but not so hot that it will burn. But it is in the engine compartment so hard to gauge. It was wicked hot when it was mounted to the block; my infrared indicated 180* at one point. Can't really say if that was due to higher dwell or being mounted to the block, but the cut-outs stopped immediately after I moved it.
@Porschef , I think it needs airflow, like James describes. @Montreal914 is building his in the same location I put mine but with spacer offsets.
JamesM
post Jan 20 2021, 02:53 PM
Post #26
QUOTE(GregAmy @ Jan 20 2021, 07:11 AM) *
Sounds like we're brothers from another mother...
I can't say enough how happy I am with the Microsquirt system I did last winter (with "bespoke" harness).
However, I'm now building an AW11 Toyota MR2 race car, and I am even more impressed at DIYAutotune's PnP system for it. I mean, it is seriously one well-thought-out bit of kit; I'm shocked that not all AW11 cars are running these ECUs. If we could only design and fab a PnP system for the 914 DJet harness... On the other hand, I can't leave well enough alone either: I've already ditched the AFM, added wideband, and I have COPs and a 36-1 coming in for it...
Subscribing! - GA
Edit: for future consideration, I am now using the 14Point7 Spartan 2 Lambda controller for my installs. Tighter install and has a much heartier lifecycle reputation than the LC2 (I've already replaced the O2 sensor in the LC2 in the street car). I get mine from a buddy, Conover Motorsports: https://www.raceconover.com/shop/spartan2
(IMG:style_emoticons/default/beerchug.gif) indeed brother! I kept an eye on your build when you posted it, I was impressed as a lot of people struggle with MS builds but it looked like you knew your stuff. Very clean.
Ill have to crack open that ECU I removed and show you what is inside. PnP to D-jet is basically what it is though, should plug into any d-jet car with minimal effort. I added other features later on hence the additional wires out the bottom, but it originally looked 99% like a d-jet ECU from the outside.
One issue with it though is it wouldn't be legal to sell as in its current state it violates the MS license agreement by running a custom PCB. The Microsquirt module used in the all the PnP systems these days wasn't around back when i built this thing so i just had to wing it. Somewhere on an old hard drive I have the gerber files for a PCB I designed using the MS 2.2 circuit diagrams that would have been a direct replacement replacement for the board in a d-jet ECU. I think I may have posted pictures somewhere on this board of it back in the day. Never went so far as to get it printed though due to all the legality questions (IMG:style_emoticons/default/biggrin.gif)
A similar thing could be done with a lot less effort and legally these days using a Microsquirt module on top of a breakout board to the d-jet harness, but knowing the limitations of the design of the d-jet harness itself and the fact that most peoples harnesses are pretty trashed at this point, I question if it would be worth it.... If you have to replace the harness anyways due to damage may as well replace it with something of a better design. Just my current feelings on it anyways after having ran with a d-jet harness for so long.
I have had various ideas and designs for PnP ECU replacements as well as PnP systems that involve harness replacement in my head for years, Im not in the parts supplying business though and really just get enjoyment out of coming up with this stuff. Sometimes I seed the ideas to others to let them run with it. There may or may not be a shop local to me now working on some other parts to facilitate easy Megasquirt conversions, at least for their customers cars, but i don't want to spill the beans and will let them speak to that if they want (IMG:style_emoticons/default/biggrin.gif)
Montreal914
post Jan 20 2021, 03:18 PM
Post #27
Just read the whole thread! (IMG:style_emoticons/default/smile.gif) Super nice installation!! (IMG:style_emoticons/default/cheer.gif)
I did a pause in my Microsquirt conversion to address rust repair before getting my car painted. I am definitely in one of these "while I am in there" thing... (IMG:style_emoticons/default/rolleyes.gif)
I am looking forward to get back into it, maybe while the car is at the body shop. The power train is currently removed and complete. Probably fairly easy to make a temporary setup to try starting it. But before that i will need to complete the Microsquirt install.
Here is my coil bracket I did out of ~16ga steel. It also supports the MPS and does mount on the tin and distributor stud. Raised, it incorporates three studs so it supports the coil like it was intended. The coil is off of the bracket base by a small gap, but after @GregAmy 's experience, I fear it might overheat. (IMG:style_emoticons/default/dry.gif) Also, since then, I went with @JamesM recommendation and got another MPS for barometric pressure, so that will need a location too...
James, will there be any cover on your ECU or it is just a support structure? I have been debating as to where to put the ECU. Greg cleverly installed his underneath the relay box, I was thinking maybe inside the cabin, away from the heat. The stock location is appealing though.
Definitely following this thread closely (IMG:style_emoticons/default/smilie_pokal.gif)
GregAmy
post Jan 20 2021, 03:45 PM
Post #28
QUOTE(JamesM @ Jan 20 2021, 03:53 PM) *
...but knowing the limitations of the design of the d-jet harness itself and the fact that most peoples harnesses are pretty trashed at this point, I question if [a D-Jet PnP system] would be worth it.... If you have to replace the harness anyways due to damage may as well replace it with something of a better design. Just my current feelings on it anyways after having ran with a d-jet harness for so long.
That's where I was, too. Once I committed to needing a new harness, the possibilties opened up...and I suddenly found myself surrounded in wires and wire bits...
If we could find someone to fab up these harnesses - I have mine fully documented - these could be easy mostly bolt-on installs for someone else. But, as with you, I'm not in the parts business and I don't want to get into the biz of fabbing harnesses, I just couldn't do it at a price that would make sense to others.
- GA
JamesM
post Jan 20 2021, 05:12 PM
Post #29
QUOTE(GregAmy @ Jan 20 2021, 01:19 PM) *
Yeah, for sure check all the plug gaps then. It may have been a fluke thing we encountered with a bad plug but after seeing it occur I did some more reading/research on the subject and turns out this is a known side effect of wasted spark systems so worth keeping an eye on.
In your case though it does really sound like you have it isolated to being heat related.
JamesM
post Jan 20 2021, 05:29 PM
Post #30
QUOTE(GregAmy @ Jan 20 2021, 02:45 PM) *
- GA
I believe there is actually something in the works (or at least discussions of such) between a couple well known vendors on this front. I think some people are starting to realize that in addition to all the benefits, after market injection of some sort will eventually wind up being a necessary for most to keep their cars drivable.
Already seeing similar things in the Vanagon world where complete bolt on systems are available from vendors. I think once a 914 specific system is widely available and base maps exists for a standardized system out of the box that will have them already 90% dialed in after bolt on we should see a lot more interest and adoption. Interest for sure has already been picking up but the steep learning cure and fab work is a blocker.
JamesM
post Jan 20 2021, 05:44 PM
Post #31
QUOTE(Montreal914 @ Jan 20 2021, 02:18 PM) *
2nd map sensor is for sure recommended if you have some extreme elevation changes, my weekend drive has me going up about mile in altitude and the absense of live correction was noticeable at the top. Without it the MS still does barometric correction however the correction is based on a set altitude where you start the car rather than a constant correction based on your current altitude.
From what I have read though, due to vibration and heat you dont want the MAP sensors mounted on the engine itself. I had considered just putting a plate where the stock d-jet pressure sensor mounts on the passenger side of the engine compartment and mounting both sensors there but as I had room in the ECU case i just mounted them there to get them more out of the way. As for covering the ECU assembly, not at this time. I would have liked to do as i had previously and have everything buttoned up inside the stock ECU housing however there isnt enough depth in the housing to allow the Microsquirt to fit unmodified, so for now its just a bracket. Had a couple ideas but still noodling on it. Its not bugging me to much yet though as it is still massively better than the rats nest that came out.
post Jan 20 2021, 07:57 PM
Post #32
Great read James. Excellent results. I applaud your work but mostly your desire for improvement. I remember watching for your updates before I went to the Dark Side several years back. I think your pioneering efforts will allow many to experience all that the "Type 4" can be. Keep up the great refinements. (IMG:style_emoticons/default/beerchug.gif) Hopefully I'll see you at RRC 2021. Kent
JeffBowlsby
post Jan 20 2021, 08:50 PM
Post #33
Someone needs to speak up against what some may misperceive from some of the potentially misleading rhetoric of this thread. The passion shown for wanting to improve is interesting and admirable but comes with words of caution: Many things in this thread can be misinterpreted by those that may be lesser informed. They read words like these implying defects to the OEM systems and components:
"...Lots of advantages over stock d-jet injectors..."
"...but knowing the limitations of the design of the d-jet harness itself..." and "...Just my current feelings on it anyways after having ran with a d-jet harness for so long...".
And then surprisingly with caveats like "...One issue with it [the suggested 'improvements'] though is it wouldn't be legal to sell as in its current state it violates the MS license agreement by running a custom PCB..."
There is nothing fundamentally wrong with OEM injectors, harnesses or other parts...although they may need maintenance replacement now or in the future like any car does. Millions of cars from that era were manufactured using these simple systems and components with many of these cars still roadworthy today.
Come down to reality gents. Acknowledge that you are merely exploring nuances, refinements and subtleties at a much more intricate level than D-Jet or L-Jet was ever intended to be, and that it does not functionally need to be. You can reengineer and refine and throw lots of R&D time and money into creating one-off 'betterments' that are interesting and may offer subtle improvements but are not essential to a correctly functioning, reliable, easy and economical to maintain TIV engine unless you just are interested in the exploration and process. Hats off to you for all it takes to pursue these efforts but don't pose them in the light of being desirable or essential to the masses, or worse that D-Jet/L-jet are somehow deficient, or less worthy than the improvements proposed.
Countless VWs, 914s, MBs, and other cars run these stock FI systems daily even today with their stock components and they work as intended. Maintenance replacements for everything are available unlike one off solutions that may need specialized or custom replacement parts that may not be available in the future - and someone knowledgeable to work on/maintain them.
The stock D-Jet (or L-Jet) are reliable, well-designed and built, and durable for what they were intended to do given the state of technology of the 70s for a production vehicle. Its much less expensive and time consuming to just maintain the stock system with stock parts for the average 914 owner who wants to just simply drive and enjoy their car.
Chasing the extreme may be OK for some to pursue but its not necessary or even desirable for the masses.
By the way...I agree with you on one thig that you are not comfortable with....loose that corrugated slit harness casing unless it is just for temp mock-up purposes, it does not protect against water getting into the harness and its electrical connections. The poly braid is no better and not suitable for our open engine bays. Use a sealed, heat-resistant casing...like the factory OEM heat shrink tubing or better.
JamesM
post Jan 21 2021, 01:40 AM
Post #34
Hey Jeff! figured I would see you here eventually.
Was thinking about you while I was fighting to piece together a working D-jet system on my bumblebee a few months ago. Cant count the number of times I said "I wish i could just throw a Megasquirt system on this", but some things are to sacred. (IMG:style_emoticons/default/biggrin.gif)
D-jet is a fine system for what it is and has held up surprisingly well for 50 years now. I didn't start this post to debate that point. My commentary on this comes mainly from an analytical point of view and i dont believe anything stated here to be missleading Honestly I could probably spend hours going over the improvements in injection technology since d-jet but I'm not here to prove anything, just share in 914 adventures and discovery (though i will probably wind up going over a lot of the points eventually just because i love talking about this stuff)
You seem somewhat defensive every time this subject comes up and im not sure why as there are some non-debatable points on this matter that are just undisputable realities that we need to face. For instance:
311 905 301
280 160 001
311 906 081 A
022 115 542
Those part numbers and many others present a problem as to sustaining the operability of our cars long term if we remain on d-jet, that is just a fact of life. Aside from the car I enjoy experimenting on I have kept my other 914s all running d-jet to this day, but that road is getting real bumpy and we may be approaching the end. This isn't just about improving, there are many factors to take into account.
For instance (and i don't mean to get anyone riled up by i know this next statement probably will) Some people (particularly those selling engines and servicing customer cars) are starting to see d-jet as a potential liability at this point. Consider the fact that a Type 4 motor will run surprisingly well across a fairly wide range of fuel mixtures and timings, so well in fact that many wouldn't even realize something may be amiss with their car if they have not added multiple additional gauges to monitor. Unfortunately the actual AFR+timings needed that keep that same motor from melting down over the long run is a much narrower window. Its pretty well known at this point that due to the analog nature and design choices of d-jet your mixture is already drifting around quite a bit just in day to day operation, add to that 50 year old components to which new replacement parts are NOT available and you are basically gambling with your motors longevity. I wouldn't be speaking about this stuff if I had not seen it first hand. Was driving behind another member out to RRC a few years ago and got my car bathed in oil from his exhaust after his faulty 50 year old injection (that happened to be running well enough not to notice there was an issue) burned a hole through his piston in his recently rebuilt motor
I personally dont enjoy driving with one eye on the gauges at all time, I want to know my injection is doing what its supposed to be doing without me babysitting it.
You may call that nuances, i call it piece of mind. Really the only reason I am comfortable driving my d-jet cars across the country, is because I am completely comfortable with the fact that my motor may very well blow up before i get there. Not everyone can say that.
And all due respect but saying things like:
QUOTE(JeffBowlsby @ Jan 20 2021, 07:50 PM) *
tell me that 1. You have absolutely no clue what we are talking about and 2. You just seem to be looking to troll this thread
And yes, d-jet does have fundamental deficiencies that go beyond the fact that its 50 years old and new parts are NLA, This is evidenced by ALL THE IMPROVEMENTS THAT WERE MADE TO BOSCH INJECTION SYTEMS OVER THE LAST 50 YEARS, not to mention the obvious fact that Bosch was attempting to chase down and correct issues with it throughout 914 production. Why do you think they added that knob to the ECU in 72 among other system corrections over the years? If you want to educate yourself on this matter you could start by reading up on why critical sensors shouldn't be grounded directly to the engine. I may get more into all of the other specific issues eventually but really not interested in spending any more time defending against a trolling at the moment.
JamesM
post Jan 21 2021, 02:24 AM
Post #35
To get this thread back on an more interesting note...
Cracked open the insides of the MS to D-jet Franken-ECU that I have been running on the car for the last 10 or so years to take a picture for everyone, was a lot prettier before the additional hacks i made to it. Thinking ill probably wind up doing a little clean up and re-purposing this.
I actually have a 2nd board I had built back then intended to improve upon a couple things i didn't like about this one but never wound up installing it in a case
If anyone wants specifics on how to accomplish this I can go into it, but I wouldn't recommend most, or really anyone, take this route.
Frank S
post Jan 21 2021, 03:37 AM
Post #36
Region Association: Germany
QUOTE(JeffBowlsby @ Jan 21 2021, 03:50 AM) *
Jeff, I think you misinterpret the Injector and the harness topics.
There is nothing wrong with the original low impedance Injector if you run D-Jet, but they are not ideal to deal with if you use them with a modern EFI system. Same with the wiring Harness, it's working perfect with D-Jet but with a modern EFI system you do not want to coupple in any noise (as digital systems are much more sensitive to noise) and therefore you have a different grounding philosopy as well.
That said, for modern EFI James way of working is the right one.
At the end everybody needs to decide himself if it is better to stay original or upgrade to something else, and some people out there even call it an upgrade if they remove D-Jet and mount carbs instead... All about personal preferences...
Take care,
Frank
Frank S
post Jan 21 2021, 05:58 AM
Post #37
James,
I did not work with Microsquirt so far and am curious how you set the voltage correction for the injector dead time as it is not linear. Does Microsquirt have a none linear correction table like MS3, or how do you deal with the problem?
Thanks and best Regards,
Frank
BeatNavy
post Jan 21 2021, 07:10 AM
Post #38
QUOTE(Frank S @ Jan 21 2021, 07:58 AM) *
James,
Frank
Hi Frank,
I don't think it has a non-linear voltage correction for dead-time. It does for dwell, but for dead time settings I think you get one shot as per picture below:
GregAmy
post Jan 21 2021, 08:05 AM
Post #39
QUOTE(JamesM @ Jan 20 2021, 06:29 PM) *
Well, I hesitate to freely offer my tune, simply because of the risk of someone simply bolting on and walking away.
But my engine is a dead-stock "Lord knows how many miles" engines and mine is a solid, safe tune. If a vendor were to offer the same exact components as I am, I'd be comfy giving them this tune as a baseline for their products, even without wideband feedback for EGO correction.
The aftermarket for something like this is an oddball, as you always risk someone taking componentry made for a different config, bolting it on, and damaging something. Then they come back blaming you.
I'm having a 2056 built right now, so no more developement on the stock engine.
Frank S
post Jan 21 2021, 08:10 AM
Post #40
QUOTE(BeatNavy @ Jan 21 2021, 02:10 PM) *
James,
Frank
Hi Frank,
Thanks for clarification Rob, it's identical with the options/settings I have available with MS2
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 13th July 2025 - 06:07 PM
