Questions About Flipping 5th for 3rd, Read Some Threads But Still Confused |
motorvated |
Jan 20 2021, 03:15 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
I just purchased a used Q gear set for my 901 transaxle and I am planning on flipping 5th for 3rd, using the Q for 4th, and 4th for fifth for my race car. I have read threads about how to "flip" 5th, implying that it is as simple as swapping the two gears of the 5th gear set to the opposite shafts where the old 3rd was located, driving to driven and vice versa. I haven't yet opened up and pulled the gear stack from the case, so maybe things will become clear to me when I do. Right now as I look at my new Q gear set, I see that one gear has internal splines (the driving gear I assume) and the other has a smooth bore (driven gear with syncros and dog teeth). See photos below of Q gear set.
I assume that the fifth gear set that is in the stack is of the same configuration, and if so, I do not see how the two gears can just we swapped onto the opposite shafts, as the gear with the internal splines would no longer be located on the splined driving shaft and the internal diameters of the gears are not the same. Also I am unsure of how the fifth gear syncro configuration is supposed to work with the flip. Since the syncro is on the driven gear, once flipped, won't it now be in the wrong position being on the driving gear? I apologize if my questions indicate that I really don't understand how this is supposed to work, but at this point, I really don't. Any and all help/advice will be appreciated greatly. I have already purchased Dr. Evil's rebuild DVD which I think will answer some of my questions, but I'm not sure if the DVD covers a 5th gear flip. |
davep |
Jan 20 2021, 11:18 PM
914 Historian Group: Benefactors Posts: 5,143 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Basically, for the third, fourth and fifth gears there are two types: those designed for third gear position, and those designed for fourth & fifth position. You can flip a gear designed for third position to use for fourth or fifth position, and you can flip a gear designed for fourth or fifth position to use for third position. When flipping you do two things: the ratio is reversed, and the gear is driven backwards from the design perspective. Inverting a ZD fifth gear 31:22 becomes a 22:31 which is very nearly a K gear, so they call it a KA gear. likewise the HB gear 19:31 (a 4-speed second gear is exactly the same as a 5-speed third gear because first in a 5-speed is in zero position on a 4-speed) when flipped becomes 31:19 which would be about ZG range (way overdrive .63 to 1 ratio). Most people do not worry about driving the gear in reverse which puts some of the thrust in the wrong direction. You can see the angle of the gear where they mesh is handed, and if you flip them the handedness is reversed. The factory had a solution, and from gears M through R there are two versions; one for third gear position and the other for fourth or fifth position.
Lo-Fi Version | Time is now: 17th May 2024 - 09:41 AM |
