Defrost fan rehab and rebuild thread (fresh air fan), or How the heck do if fix this thing? |
DRPHIL914 |
Jan 21 2021, 08:55 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have been dealing with this for 12 years, a non-running defrost fan. i even pulled this out 2 years ago and rebuilt it with new flapper seals and main body seal then made sure fan turned but didnt bench test the motor or resisitors, so as a result it still does not work properly. i will be documenting this because 914rubber and Mark will soon be putting together a kit for this that includes all the hardware seals and even a motor i believe, BUT i still have problems and questions!!! so i am starting this thread to get information on diagnosing the common causes of it not working and how to fix it, and then document the rebuild and replacement of the motor, fan, resistor and maybe the control unit in dash. Others have documented the reinstallation of the fan and the cables so i will not duplicate that. and we may want to link other threads hear that have done that as well.
Mark is sending me a kit soon, so while i wait for it, i will have to get some more information about the wiring and resistors function and how to test them . I had this out last week and tested 3 different control units due to thinking that my issue was a control issue, because it runs on one speed, #2, and anything else does not work and it will then throw the fuse. most assume this would be caused by bad slider unit but i tested 3 of them and 2 are like new with no wear on the sliders , still same result. so i am suspecting the resistors /plug aparatus . If anyone has done this and cares to share how to examine and test that for proper function, lets start there. Resistor function, which lead is which and examination of the control units I will take pictures of mine tonight and post those soon. once this figured out and fixed i will do a full step bystep on reassembly too. Looking for lots of help and input on this, thanks!!! Dr. Phil |
BeatNavy |
Jan 21 2021, 11:41 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Phil, if it runs on one speed but not another (or the other two), it's likely a blown resistor. Too much resistance builds up through the ground circuit and it fries. I remember shortly after putting mine back in after cleaning it up -- I put it on low speed and saw a little puff of smoke came up through the vent grill. IIRC it uses three resistors in different combinations to control the effective voltage supplied to the motor. I have a fresh resistor pack that BillC sold me a few months ago. I'll see if I can find that for reference (although doing this wasn't high on my priority list, so I may have buried it with my other parts that I'll get to "one day.")
DRPHIL914 |
Jan 21 2021, 12:05 PM
Phil, if it runs on one speed but not another (or the other two), it's likely a blown resistor. Too much resistance builds up through the ground circuit and it fries. I remember shortly after putting mine back in after cleaning it up -- I put it on low speed and saw a little puff of smoke came up through the vent grill. IIRC it uses three resistors in different combinations to control the effective voltage supplied to the motor. I have a fresh resistor pack that BillC sold me a few months ago. I'll see if I can find that for reference (although doing this wasn't high on my priority list, so I may have buried it with my other parts that I'll get to "one day.") thats kind of what i figured, i found your thread from a couple years ago, you were working thru your issue and had figured out which wire was what. I have 2 other fan boxes and i hope i have one good resistor pack , because i have tried looking and have not found any out there id dont think they can be bought anymore. i might post a WTB ad on classifieds here as well. thanks for the input! Phil |
Lo-Fi Version | Time is now: 14th May 2024 - 03:17 PM |
