Defrost fan rehab and rebuild thread (fresh air fan), or How the heck do if fix this thing? |
DRPHIL914 |
Jan 21 2021, 08:55 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have been dealing with this for 12 years, a non-running defrost fan. i even pulled this out 2 years ago and rebuilt it with new flapper seals and main body seal then made sure fan turned but didnt bench test the motor or resisitors, so as a result it still does not work properly. i will be documenting this because 914rubber and Mark will soon be putting together a kit for this that includes all the hardware seals and even a motor i believe, BUT i still have problems and questions!!! so i am starting this thread to get information on diagnosing the common causes of it not working and how to fix it, and then document the rebuild and replacement of the motor, fan, resistor and maybe the control unit in dash. Others have documented the reinstallation of the fan and the cables so i will not duplicate that. and we may want to link other threads hear that have done that as well.
Mark is sending me a kit soon, so while i wait for it, i will have to get some more information about the wiring and resistors function and how to test them . I had this out last week and tested 3 different control units due to thinking that my issue was a control issue, because it runs on one speed, #2, and anything else does not work and it will then throw the fuse. most assume this would be caused by bad slider unit but i tested 3 of them and 2 are like new with no wear on the sliders , still same result. so i am suspecting the resistors /plug aparatus . If anyone has done this and cares to share how to examine and test that for proper function, lets start there. Resistor function, which lead is which and examination of the control units I will take pictures of mine tonight and post those soon. once this figured out and fixed i will do a full step bystep on reassembly too. Looking for lots of help and input on this, thanks!!! Dr. Phil |
Superhawk996 |
Jan 29 2021, 07:04 AM
914 Guru Group: Members Posts: 5,815 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
For what it's worth good luck balancing one of these fan impellers.
They are dynamically balanced using a tachometer and an accelerometer. You'll notice the impeller has degree markings on it. The tachometer keeps track of RPM as the impeller/motor assembly is spun. The accelerometer is used to find at what angle the peak acceleration occurs. Knowing that information, a weight can be installed 180 degrees off of the peak acceleration. Rinse lather repeat until vibration is minimized. Not easy to duplicate in our hobby garages. Static balance would achieve very little. It can be done in a trial and error way in the same way you might balance a home ceiling fan with a penny. The problem with this is 1) they spin way faster which means a very small weight has quite a large effect. 2) They have so many vanes on the impeller you have a lot more trial and error options on where to place the weight. 3) Determination of minimal vibration becomes highly subjective. My bet is that is why the OEM motor/impeller assembly costs the money it does vs. the URO assuming it isn't balanced. |
DRPHIL914 |
Jan 29 2021, 12:16 PM
For what it's worth good luck balancing one of these fan impellers. They are dynamically balanced using a tachometer and an accelerometer. You'll notice the impeller has degree markings on it. The tachometer keeps track of RPM as the impeller/motor assembly is spun. The accelerometer is used to find at what angle the peak acceleration occurs. Knowing that information, a weight can be installed 180 degrees off of the peak acceleration. Rinse lather repeat until vibration is minimized. Not easy to duplicate in our hobby garages. Static balance would achieve very little. It can be done in a trial and error way in the same way you might balance a home ceiling fan with a penny. The problem with this is 1) they spin way faster which means a very small weight has quite a large effect. 2) They have so many vanes on the impeller you have a lot more trial and error options on where to place the weight. 3) Determination of minimal vibration becomes highly subjective. My bet is that is why the OEM motor/impeller assembly costs the money it does vs. the URO assuming it isn't balanced. makes sense , every one i have opened up has different amounts and local of metal clips on fins that i assume are the balancing weights . good point on the balancing, maybe Drew aka @uropartsguy will chime in and tell us if any balance testing is done |
Lo-Fi Version | Time is now: 14th May 2024 - 12:10 PM |
