Defrost fan rehab and rebuild thread (fresh air fan), or How the heck do if fix this thing? |
DRPHIL914 |
Jan 21 2021, 08:55 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have been dealing with this for 12 years, a non-running defrost fan. i even pulled this out 2 years ago and rebuilt it with new flapper seals and main body seal then made sure fan turned but didnt bench test the motor or resisitors, so as a result it still does not work properly. i will be documenting this because 914rubber and Mark will soon be putting together a kit for this that includes all the hardware seals and even a motor i believe, BUT i still have problems and questions!!! so i am starting this thread to get information on diagnosing the common causes of it not working and how to fix it, and then document the rebuild and replacement of the motor, fan, resistor and maybe the control unit in dash. Others have documented the reinstallation of the fan and the cables so i will not duplicate that. and we may want to link other threads hear that have done that as well.
Mark is sending me a kit soon, so while i wait for it, i will have to get some more information about the wiring and resistors function and how to test them . I had this out last week and tested 3 different control units due to thinking that my issue was a control issue, because it runs on one speed, #2, and anything else does not work and it will then throw the fuse. most assume this would be caused by bad slider unit but i tested 3 of them and 2 are like new with no wear on the sliders , still same result. so i am suspecting the resistors /plug aparatus . If anyone has done this and cares to share how to examine and test that for proper function, lets start there. Resistor function, which lead is which and examination of the control units I will take pictures of mine tonight and post those soon. once this figured out and fixed i will do a full step bystep on reassembly too. Looking for lots of help and input on this, thanks!!! Dr. Phil |
Superhawk996 |
Feb 4 2021, 09:38 AM
914 Guru Group: Members Posts: 5,812 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
This is what I was calling the blower housing frame, not so much the motor housing itself.
This is the heavy part! The other motor frame is also cast pot metal and is an open metal frame. The permanent magnets were glued into the blower housing frame. Completely different DC motor construction than the motor you linked, and/or which appears to be in both your pictures and was part of the 2nd used fresh air box I recived. Blower housing frame on left, DC motor with open frame in center, pile of permanent magnets, spring clips, and fasteners on the right. The newer type DC motor that are in the URO blower and that you linked to are way lighter than these parts. Hard for me to put a vintage on these parts. My car is an early 73' but has backdated bumpers, early doors, and generally a mish mash of parts from who knows where. I suspect this is an early model based on motor construction, the inlet cowl seal, and the fact that it didn't have a plastic inlet grille but some homemade window screen! @DrPhil914 |
Lo-Fi Version | Time is now: 13th May 2024 - 11:11 PM |
